Ecuflash can't read my ECU
Old Apr 25, 2010 | 10:08 AM
tboboy's Avatar
Hey guys. I did some searching but wasnt able to come up with anything. Ive used Evoscan 2.5 and Tactrix 1.3 before on my previous EVO 9 and everything worked fine. I bought another EVO 9 and using same laptop with Evoscan 2.5 and same cable and it doesnt log and doesnt read from ECU. Downloaded Evoscan 2.6 and same thing is happening. Here is what it says on screen:
ECU flashing:
flashing tool "mitsukernel" loaded.
flashing tool "mitsukernelocp" loaded.
flashing tool "mitsubootloader" loaded.
OpenPort Cable Connected.
3064 byte kernel read.
sending init sequence 1 (0001)
interface close
Installed a brand new battery.
I did try running unlocker but no luck still.
Another person tried with his Tactrix cable and laptop and same result.
Car passed the smog, so I think they connect to OBDII port and it should be working then.
Any help? Thanks in advance
Old Apr 25, 2010 | 11:02 AM
evonut270's Avatar
Is the flash plug connected
Old Apr 25, 2010 | 11:04 AM
tboboy's Avatar
Both plugs are connected. Is the white plug supposed to have only one wire going from it?
Old Apr 25, 2010 | 11:12 AM
mt057's Avatar
I had something like this happen to me and it was the wires going in to the conector from the ecu were a little loose. I pushed on them and it worked. Good luck with it.
Old Apr 25, 2010 | 11:40 AM
evonut270's Avatar
Yes only 1 wire from the flash plug. As per above post check the plugs are tight and wires have not popped out.
Old Apr 25, 2010 | 11:45 AM
4WS Tuning's Avatar
Try driving the car around for 5-10 minutes first.. If still no luck then you need to track down an older version of ecuflash like 1.29. Shoot me a pm or email if you end up needing a copy
tamer@4wstuning.com
Cheers!
Old Apr 25, 2010 | 11:47 AM
Jim in Tucson's Avatar
Check all fuses - under hood and under dash.
More help here:
https://www.evolutionm.net/forums/ec...tart-here.html
Old Apr 25, 2010 | 11:56 AM
badhabit90's Avatar
is the ECU locked from a previous tuner?? mine is locked from WORKS..ugh...
Old Apr 25, 2010 | 12:05 PM
tboboy's Avatar
tamer@4wstuning.com
Cheers!
I tried driving the car first. Plus i just put in a brand new Optima red top in it. Thanks for the offer but Ive found older versions of ECUFlash and tried 1.29, 1.29a, 1.34 etc..no luck.
Old Apr 25, 2010 | 12:08 PM
tboboy's Avatar
More help here:
Checked fuses under hood. All good. I will try checking fuses under dash when I get home. Is it possible that under dash fuses have something to do with it? Does anyone have their diagram, or is there one under there?
I got the car without any previous history. I tried running unlocker with multiple ECUFlash versions. No luck.
Old Apr 26, 2010 | 01:11 AM
nabilsx's Avatar
just use ECU unlocker http://www.aktivematrix.com/forum/dl...4e2da9032b166a and remember to donate to Malibujack, if it was not for him, you would have to buy another ECU.
NAB
Old Apr 26, 2010 | 05:30 AM
EvowagonIX's Avatar
Im having the same problems, all my fuses are good to go.
Old Apr 26, 2010 | 05:46 AM
EvowagonIX's Avatar
and my evoscan works.
Old Apr 26, 2010 | 10:54 AM
tboboy's Avatar
Checked all under dash fuses. All good except the one on the pic is missing, Is there supposed to be one? There is a plastic tab that prevents a reg fuse to go in. What is that fuse for if there is one? Is there anything else Im missing there? How or do I need to check those big plastic black plugs/fuses on the top and left?
Uploaded with ImageShack.us
Here is the back of my OBD2 connector. 7 wires coming out seems to be connected good. Dont know what else to check. Any help is appreciated.
Old Apr 26, 2010 | 11:47 AM
tboboy's Avatar
Finally was able to read it. Used a different laptop, downloaded ECUFlash 1.29a. Used unlocker. Played with wires a bit and it worked. Not sure what the problem was. Thanks everyone for suggestions anyway.
Kieran Fercher
12
Mar 24, 2020 09:37 AM
evoscan
52
Jun 20, 2017 01:46 AM
usernameka
Apr 9, 2017 09:30 AM
D1andonlyantman
Jan 22, 2017 10:57 AM
nemean
Sep 21, 2016 03:54 PM
