TephraXMOD V1
Old May 7, 2012 | 02:47 AM
  #736
tephra's Avatar
1) are you talking about stationary rev limitter?
2) is P0133 the front or rear? I think its front. in which case you should fix it if its rear - just use the ecu-options-2 bit.1 to disable it
Old May 7, 2012 | 04:15 AM
  #737
Aleks330's Avatar
1. Yes, stationary rev limit.
2. I need to disable dis code, because I install standalonrle ecu. Its front sensor
Old May 7, 2012 | 05:08 AM
  #738
masafina's Avatar
the stationary rev limit don't work
Old May 12, 2012 | 01:59 PM
  #739
sayoung2's Avatar
2012 usdm RA SST- 58030005
Hey there,
So far theres nothing on 2012 ralliarts legit nothing i would like to start logging but im geeting insanely frustrated anyway you could post the XML with the code for this hex ??
thank you ps any buddy know how to see all the maps i have the goldenevo xml but i cant get anything ive tried the tutorial and i get how it works but my maps wont show up
lol hulk smash
File Type: hex
Old May 12, 2012 | 05:33 PM
  #740
richardjh's Avatar
sayoung2, we'll sort all this out as part of the Base Map work. That way, we can avoid using the tephraXMOD thread to work out starter EcuFlash XML configuration.
You has pm.
Rich
Old May 26, 2012 | 07:08 AM
  #741
Bob_tm's Avatar
Any news about live mapping?
Old May 30, 2012 | 06:49 PM
  #742
EvoXSly75's Avatar
Proudly supporter of your stuffs, thanks!!!
Old Jun 10, 2012 | 10:42 AM
  #743
gtrskyline34's Avatar
tephra,
Any fixes on P0137? I know there's one for the evo 8,9's but is there one for the X? Props for your great work!
Old Jun 12, 2012 | 10:52 AM
  #744
narshe's Avatar
Are there any 2012 USDM roms coming?
Is there anything I need to submit or do to help?
Old Jun 13, 2012 | 11:23 PM
  #745
xhomm02's Avatar
Hi,
I really look forward to have this option aviable via Cobb AP.
Just wanted to ask if all the learned parameters (LTFTs, learned knock, learned idle throttle posistion etc. ) are reset with map swich or they remain remembered?
Old Jun 14, 2012 | 09:32 PM
  #746
hotstix's Avatar
Any chance we will be will be able to disable p0300?
Old Jun 14, 2012 | 09:40 PM
  #747
murlo26's Avatar
I have asked him about this before several times, he wasn't really into disabling it. He said he saw no reason to when I asked, maybe his mind has changed with his full build who knows.
For whatever reason, my P0300 hasn't popped up since last fall, so not at all this year (knocks on wood).
Old Jun 14, 2012 | 10:30 PM
  #748
hotstix's Avatar
hmm, I thought it was commonly diasbled on the 8/9s? Anyway, nie pops up constantly. I know its not a real misfire, becuase it is nver cylinder specific. Its just annoying.
Also, I keep getting the p0219 Over rev code. I think its only an issue for 2010 and up, but with a built head and revving to 8.5k, the ECU thinks I ovveredd the engine and trips that code.
Old Jun 15, 2012 | 06:28 AM
  #749
murlo26's Avatar
Yea the 8/9's have the disable for this, but they would get p0300 from the factory even, the code was literally on stock vehicles. They tried a reflash which didn't really fix it.
Glad I have the 08 to avoid the p0219...the only one I have had lately was the p0069 and Jon fixed that now
Old Jun 15, 2012 | 07:47 AM
  #750
tephra's Avatar
I got P0300 a few times with the new motor.
it was always because the AFR was a bit to lean.. and it misfired...
