TephraXMOD V1
Old Jun 17, 2012 | 08:04 PM
  #751
Golden's Avatar
I tuned a 2011 today that has a lightened flywheel. It threw the p0300 like crazy. It was not misfiring. I think the flywheel is setting off the code.
Old Jun 17, 2012 | 11:37 PM
  #752
hotstix's Avatar
yup. This is my life.
Old Jun 18, 2012 | 09:01 AM
  #753
Golden's Avatar
I have a light flywheel that will be installed soon. I'm hoping I don't have the same results, but we will see. According to Eric (at SSP), I will have the P0300 issues.
Old Jun 18, 2012 | 10:17 AM
  #754
murlo26's Avatar
I have the streetlite flywheel from ACT, which is lighter than stock (i believe) but not by much. I wanted more mass for drag anyway at the time.
I had a lot of P0300's before, like at least 1 a day, so i assumed it was my flywheel. But now with a new tune/tuner those seem to have gone away, so i am thinking it was actual misfires probably from running lean during cruise/idle.
So I am guessing the reason Tephra or people are hestitant to add a p0300 disable is it could be used for tuners to easily cover up actual problems. But might have to if lightweight flywheels really are that bad, who knows.
Old Jun 19, 2012 | 10:09 PM
  #755
ChiefMak's Avatar
I had a local tuner flash the v1 into my 2008 MR and do a road tune. Before that, we put the car through it's paces to get the stock numbers with a racelogic for comparison. We used the launch control to get the best possible 1/4 mile time but it would not work anymore after flashing the v1. Would the v1 disable the launch control feature?
Thanks!
Mak
Old Jun 19, 2012 | 10:30 PM
  #756
hotstix's Avatar
If there is one thing I could have changed about my build it would be the lightweight flywheel. I hoenstly wish I would have just stuck with a resurfaced OEM. Its not like these are 350z dual mass flywheels that weigh 42lbs, I thnk they are 12lbs or something stupid light already.
Old Jun 20, 2012 | 01:22 AM
  #757
tanksmith's Avatar
I so need to bypass this p0300 had ams tune the car and still have this code popping up
Old Jun 20, 2012 | 04:58 AM
  #758
chetrickerman's Avatar
Veteran: Army
I suggest you find out why you are actually getting the code first
Old Jun 20, 2012 | 05:11 AM
  #759
tanksmith's Avatar
[QUOTE=chetrickerman;10233468]I suggest you find out why you are actually getting the code first[/QUOTE
Well I asked ams and they told me it was common on the evo x , iam not sure what else to do
Old Jun 21, 2012 | 06:18 AM
  #760
hotstix's Avatar
[QUOTE=tanksmith;10233485]
You have a light weight flywheel?
Old Jun 22, 2012 | 07:43 AM
  #761
tanksmith's Avatar
[QUOTE=hotstix;10235902]
No but I do have a twin disc setup
Old Jun 23, 2012 | 03:12 PM
  #762
masafina's Avatar
tephra!!!!!!!
ralli 2009 please
Old Jun 24, 2012 | 08:04 PM
  #763
nastorino's Avatar
Is the tephra mod available for the 2012 GSR X's yet?
Old Jun 25, 2012 | 08:56 PM
  #764
Golden's Avatar
I believe that you have to Email Tephra for those.
Old Jun 26, 2012 | 04:58 AM
  #765
masafina's Avatar
oh ok, thank you
