v7 - WGDC question - 96530706 rom
in order to log airflow 2byte...someone posted to change 02 and 03 in the mut table to 89BA and 89BB respectively.
however looking at the MUT you have setup with the hex, 89BA and 89BB are actually in MUt 04 and 05.
so i assume you are logging 2byte airflow with 04/05?
Hello !
What do you think 100% TPS WGDC correction table can cause what is in the log ? I think no.. so interesting !
evo 8 small 9.8 turbo gm 3 port boost control, 58% TPS and boost is near 27psi ?!! why wgdc at 85-90% instaed of the 62% what is in the main map wastegate duty table ?!
boost error correction table zero out !
try to set tps wgdc table something like this ?
TPS% Max Corr
0 0
13 0
25 0
38 0
50 0
63 0
75 0
88 10
100 10
I have never seen something like this on Evo 9 or Evo 8 with 9 turbo with 100% tps corr .
TPS% Max Corr
0 0
13 0
25 0
38 0
50 0
63 0
75 0
88 10
100 10
More logs about the issue.. wgdc set 100% until load 150, main map wgdc table as in my last post and some times the Ecu doesnt follow the table and set 90-85% wgdc what is causeing over boost ?!
wgdc fix 80% ?! why ?
wgdc 80% to 85% ?!
wgdc 90 to 85 % ?!
most interesting same log on the left side everything is right wgdc following the table 62% no overboost, later on the left side wgdc is 90% ?!
I have no idea what can cause this ! No error correction upward correction evertyhing is zero out.
Rom is V7 9653 on a US evo 8 . Will try the 94170715 rom, but any idea please lets write it ! I had no similiar problem with the 9653 in the past .
wgdc 80% to 85% ?!
wgdc 90 to 85 % ?!
