Interesting remap in JDM car
Old Aug 6, 2010 | 11:36 AM
  #76
tscompusa2's Avatar
Originally Posted by D-VO
Did you guys have the knock load tables defined? I'd like to see what that looks like as well. Also, was anything discovered when removing the 61? I think the community should know this.
yes the 61 was someone that didnt know how to tune knock out and put it to 61 so it never knocks.. we set that back to around 18. the car now has 0 knock with my tune.
Old Aug 6, 2010 | 11:37 AM
  #77
hediki12's Avatar
Originally Posted by tscompusa
The only tables I changed were
The main fuel and timing maps and the knock multipliers.
Heres the additional stuff you want to add to the XML to display the knock settings.
<table name="Knock Load Table 1" category="Knock Control" address="407e" type="2D" level="2" scaling="Load8">
<table name="X" address="4d76" type="X Axis" elements="10" scaling="RPM"/>
</table>
<table name="Knock Load Table 2" category="Knock Control" address="408e" type="2D" level="2" scaling="Load8">
<table name="Engine Speed" address="4d76" type="X Axis" elements="10" scaling="RPM"/>
</table>
<table name="Knock Load Table 3" category="Knock Control" address="40b0" type="2D" level="2" scaling="Load8">
</table>
<table name="Knock Multiplier - Low RPM" category="Knock Control" address="177a" type="1D" level="1" scaling="uint16"/>
<table name="Knock Multiplier - Mid RPM" category="Knock Control" address="24aa" type="1D" level="1" scaling="uint16"/>
<table name="Knock Multiplier - High RPM" category="Knock Control" address="21de" type="1D" level="1" scaling="uint16"/>
<table name="Knock Adder - Single Gain" category="Knock Control" address="1780" type="1D" level="1" scaling="uint16"/>
<table name="Knock Adder - Triple Gain" category="Knock Control" address="177c" type="1D" level="1" scaling="uint16"/>
tom! just found out the adress is WRONG!!! after digging around alot! it made no sense why even the stock 9055 roms had a mid of 61
here ya go...
Code:
 <table name="Knock Load" category="Knock Control" address="407e" type="2D" level="2" scaling="Load8">
    </table>
    <table name="Load required for Octane update" category="Timing" address="408e" type="2D" level="2" scaling="Load8">
    </table>
    <table name="Knock Multiplier - Mid RPM" category="Knock Control" address="24a8" type="1D" level="1" scaling="uint16"/>
    <table name="Knock Multiplier - High RPM" category="Knock Control" address="21dc" type="1D" level="1" scaling="uint16"/>
Old Aug 6, 2010 | 12:54 PM
  #78
tscompusa2's Avatar
eh nm low is the same and mid/high are not. his cars not knocking either way i can tell by the timing curve.
Old Aug 6, 2010 | 01:08 PM
  #79
hediki12's Avatar
kool yea just wanted to give you a heads up.. taht the rom was fine the xml was screwed up..
Old Aug 6, 2010 | 04:01 PM
  #80
ug_orf's Avatar
thanks for the code lines hediki12, that was more than helpfull, it was a relief...
i can see this:
13low
18mid
20hi
guess thats normal.
that said, i add that i have no knock with that ignition/fuel maps...
power is 330hp afw, torque 356nm, boost stock 1,3bar on spool and 1,1bar revlimit
Old Aug 7, 2010 | 01:55 AM
  #81
Benja's Avatar
Hmmm...yeah my tune is nice and safe now.
Waiting on my wideband and front pipe to go in and i'll clean up the fuel map, then get a bit more from the timing map...
Old Aug 7, 2010 | 03:32 PM
  #82
D-VO's Avatar
Ah cool! Thanks for the definitions.
Old Aug 8, 2010 | 11:47 PM
  #83
burgers22's Avatar
This is the 90550001 xml I use, it's pretty accurate, just in case it help you guys out.
File Type: zip
Old Nov 18, 2010 | 11:01 PM
  #84
Benja's Avatar
Hey guys......I"m baaaaack into it.
TXS front pipe, LC-1, 4bar Omni Map sensor installed.
Ripped out the water spray and ran a cold air feed, boxed the HKS intake etc. etc. etc.
-Now first pull after installation shows its leaned out quite a bit, mid/high 12's through out the run until above 6k where it runs down to low 12's.
Selected the main chuck of cells that i'm trying to richen (3-6k, 180-220 load) and dropped the targets down by four points.
This richened the a/f ratio the next run, it was low 12's dropping into high 11's.
My target AFR number on the EcuFlash bin is "10.6-9.7" but my actual is ~2 whole points above this.
Does this indicate my fuel pump is on its way out? Presuming its stock as i've never looked, the a/f's are dropping up top though which made me think not.
I know the MAF scaling can sort this out but is that such an issue with a stock turbo/injector/pump setup?
Cheers.
Old Nov 19, 2010 | 12:21 AM
  #85
tscompusa2's Avatar
no try pulling some more off and see if it goes richer. .4 isnt enough to take mid 12's to mid 11's. try .3 more
Old Nov 19, 2010 | 01:22 AM
  #86
Benja's Avatar
Cheers Tom.
I was just curious though as this is the first changes to the map you put down 2 months ago, was high 11's t the tail pipe then.
Very suprising how much the front pipe leaned it out. Not knocking though and running 14 deg up top.
Old Nov 19, 2010 | 05:00 AM
  #87
Benja's Avatar
Yeah was pretty interesting.
Getting there with it... All a learning curve though.
Old Nov 20, 2010 | 06:10 AM
  #88
Benja's Avatar
Ok got the fuel map done I think, at least for WOT 3rd gear pulls.
Here's the VD of three pulls, Green was where I left it earlier this arvo, blue is the last flash to sort out the fueling, Red is another pull about 30min later with no changes, forgot to plug the LC-1 back in though.
Forget the crazy spike though, does that sometimes.
Any suggestions on that spool up a/f? Is that ok?
Was aiming at just above 13:1 at 3k, tapering down to mid 12's at peak boost and then 11.7 by 4k.
Then rocks between 11.5-11.6 until ~6500 where it tapers down again toward 11.2 by cutout.
Have attached the log for the Blue run.
Fuel is 98RON which is ~92.5MON.
Cheers.
Old Nov 21, 2010 | 03:25 AM
  #89
Benja's Avatar
Anyone care to comment?
Cheers.
Benja
Feb 8, 2015 10:31 PM
Benja
Jul 3, 2013 02:33 PM
Benja
May 18, 2011 11:00 PM
Benja
Apr 9, 2011 04:52 PM
Benja
Nov 28, 2010 02:09 AM
