How to setup my 2step/ launch control
Old Sep 18, 2010 | 01:51 AM
EvoPower81's Avatar
Hi guys I have been searching the forum and wasnt able to find an information on how to set up my launch control. So far all i know is how to change the rpm .I tried to do a datalog to see which load area it falls in when i engauge the 2 step so I can adjust the fuel n timing but it seems like thats not all to it. When I adjusted that area I stilll didnt build any boost. Also, Is the tephra mods alt maps used for this or just the main maps? any help would greatly be appreciated.
Old Sep 18, 2010 | 02:10 AM
VGergo's Avatar
If you enable Launch Maps in the tephra mod options than you have to adjust in the Global Launch maps section the high oct ignition and fuel map
Old Sep 18, 2010 | 03:14 PM
EvoPower81's Avatar
I dont have the launch maps in the tephra mods. Is it as simple as
1) Setting the launch rpm
2) Do a datalog to see which zone it falls in for the fuel and timing maps
3)Richen the mixture in that zone (to what afr?)
4)Pull back timing in that zone (to what degree?)
Can anyone explain it to me?
Old Sep 18, 2010 | 03:32 PM
SyZyGy1394's Avatar
Pulling timing for launching in your main timing maps is retarded. You can and will hit those cells if you actually drive your car around.
Get the launch maps.
Old Sep 18, 2010 | 04:29 PM
evo7vii's Avatar
Does an Evo 7 have a launch control. i thought since we miss the clutch switch we cant use it.
Please more info...
Old Sep 18, 2010 | 04:54 PM
EvoPower81's Avatar
Please more info...
I have a JDM evo 7 and it does have to engauge the clutch for it to start. Also I changed to 90550001 ROM thanks to "burgers22" who sent it for me. This ROM has most of the stuff defined. Im just trying to understand how to set it up now
Old Sep 18, 2010 | 04:59 PM
evo7vii's Avatar
ohh thats good... have a Euro Evo7 and can switch on without clutching that means i cant use the launch control???
Old Sep 18, 2010 | 05:16 PM
EvoPower81's Avatar
Im not sure
Old Sep 19, 2010 | 03:34 AM
grayw's Avatar
You need to use the same Tephra version of 90550001, to enable launch control.
Old Sep 19, 2010 | 05:15 AM
EvoPower81's Avatar
I have that version but the launch maps seems not to be there
Attached Thumbnails How to setup my 2step/ launch control-tephra.jpg
Old Sep 19, 2010 | 06:12 AM
grayw's Avatar
No separate launch ignition/fuel for launch control in V5.1, just a working stationary rev limiter. You will have to wait for V7 for 90550001 if you want to make adjustments to stationary ignition etc.
Old Sep 21, 2010 | 06:40 AM
EvoPower81's Avatar
Well until i get that version ill have to work with what i have. I manage to build 12psi at 5500 but no matter how i adjust the fuel it stays full lean.. Is that how its suppose to be?
Old Sep 21, 2010 | 06:44 AM
SyZyGy1394's Avatar
Its because the two step on our cars actually cuts fuel. At least thats what I recall...
Old Sep 21, 2010 | 07:05 AM
EvoPower81's Avatar
As sarcastic as u are I still appreciate your help. I am actually now learning my way through this tuning thing.
Old Nov 13, 2010 | 01:02 AM
Chameleon@NLM's Avatar
any more updates on this? I have launch maps active and -10 in my timing and 7.4's in my fuel for sections 5500-6500 rpms and no matter what i do my aem WB shows full lean during 2step. im using tephra V7 with speed density on an evo IX
im hitting up the track on sunday and as of right now the car completely bogs off 6200rpm 2step..
any help is appreciated!
audiofan
Apr 3, 2011 05:36 PM
freshevo8
May 7, 2010 05:38 PM
house_of_senate
Sep 11, 2009 07:46 AM
sekula
Sep 13, 2007 01:47 PM
05graphiteMR
Aug 24, 2006 04:08 AM
