Timing Trim Per Gear
Old Feb 29, 2012 | 05:32 AM
  #76
laramie_05MR's Avatar
I'll be able to test in a couple of weeks. 9653
Old Mar 8, 2012 | 07:54 PM
  #77
project_skyline's Avatar
tephra sent you an email about testing.
Old Mar 12, 2012 | 03:29 PM
  #78
burgers22's Avatar
Is there a 9653 with timing trim per gear? I'll see if I can port it to 9055.
Old May 9, 2012 | 11:20 AM
  #79
bump who has this so I can do some testing?
Old May 9, 2012 | 01:42 PM
  #80
211Ratsbud's Avatar
Im in for 88586714 which is the same as 88580714 just 3dsd
Old May 9, 2012 | 02:37 PM
  #81
vd's Avatar
vd
+1, I have no problem and am willing to test anything for 88580714 or 88586714
Old May 12, 2012 | 06:03 PM
  #82
Dynotech Tuning's Avatar
I have the original 9653 version he sent somewhere. I gotta find it though!
-Jamie
Old May 12, 2012 | 06:10 PM
  #83
This is for 9653 roms and is UNTESTED!!!!!!!
UNTESTED UNTESTED
Switch the address' like he has listed. Proceed with caution. This test version should change ALL timing in the map, not just at WOT.
Originally Posted by Tephra
Can you give this a whirl:
Code:
<scaling name="TimingTrim8" units="units" toexpr="x-128" frexpr="x+128" format="%.0f" min="-128" max="128" inc="1" storagetype="uint8" endian="big"/>
	<table name="Gear Timing Trim" category="TephraMod-V7" address="41c0" type="2D" scaling="TimingTrim8">
		<table name="Gear" address="6824" type="Y Axis" elements="5" scaling="uint16"/>
	</table>
	<scaling name="Hex16" units="hex" toexpr="x" frexpr="x" format="0x%04X" min="0" max="65535" inc="1" storagetype="uint16" endian="big"/>
	<table name="Gear Timing Trim Patch #1 (0x8904 -> 0x8446)" category="TephraMod-V7" address="6820" type="1D" scaling="Hex16"/>
You need to map the table so the axis as the gears (1,2,3,4,5)
I havn't bothered making a 6th gear, I figure it will be the same as 5th anyways..
-Jamie
Old May 12, 2012 | 09:54 PM
  #84
Anarchy99's Avatar
This is a waste of time when you can do gear dependent boost instead to manage cylinder pressure/anti knock
Old May 13, 2012 | 04:34 AM
  #85
burgers22's Avatar
Thanks Jamie, but that looks like just the xml deff for the map address and scaling. I think we might need some code, is there a ROM that goes with this?
Old May 13, 2012 | 05:23 AM
  #86
wreckleford's Avatar
I think the patch is in the switching of the address from 0x8904 -> 0x8446.
Old May 13, 2012 | 05:50 AM
  #87
burgers22's Avatar
Ah, looks like tephra has used an existing piece of the timing code and pointed one of the axis look up to read the RAM variable he's using for the boost/gear feature - nice.
My disassembly's sucks and I can't trace the code through fully, but will test and report when I can.
Old May 13, 2012 | 06:43 AM
  #88
burgers22's Avatar
Right, I think this should patch 90550701- but it is UNTESTED! So use at your own discretion and risk
I think you may have to adjust the "gear" column to get RPM/gear but not sure on this yet.
<table name="Gear Timing Trim" category="TephraMod-V7" address="4024" type="2D" scaling="TimingTrim8">
<table name="Gear" address="4F50" type="Y Axis" elements="5" scaling="uint16"/>
</table>
<table name="Gear Timing Trim Patch #1 (0x874F -> 0x8446)" category="TephraMod-V7" address="4F4C" type="1D" scaling="Hex16"/>
BTW for any 9055 V7 users, if you are not aware there are a bunch of fixes for boost control from donner.
Old May 13, 2012 | 10:26 AM
  #89
Oh thats right, I forget the entire world only uses ECU controlled boost It was primarily for MBC vehicles. This is still very useful with ECU Controlled boost situations as well.
-Jamie
Old May 20, 2012 | 06:18 AM
  #90
burgers22's Avatar
Gave this a pretty good test today and couldn't see any change in the timing. The timing part of the map is trim, I tried this at -5 and again at -15 in 4rd gear only but couldn't see any change in timing.
I wonder if this table is only used under certain conditions, anyone else try this patch?
