General non-information about factory ALS
Old Jun 1, 2012 | 05:06 PM
  #331
Maikumaru's Avatar
Originally Posted by 211ratsbud
Thanks, the plug i plan to use is on the manifold branch i actually confused it as an injector plug for a sec. Ill ping the location and. Pin to 4 i believe .. ill have to double check
SAS pin 4
EGR is pin 5
Old Jun 1, 2012 | 05:40 PM
  #332
211Ratsbud's Avatar
Ix correct?
Old Jun 1, 2012 | 06:39 PM
  #333
211Ratsbud's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=337757
Just for reference in future
Old Jun 1, 2012 | 08:46 PM
  #334
211Ratsbud's Avatar
How come you never tried 8858 maik?
Old Jun 1, 2012 | 11:36 PM
  #335
donner's Avatar
Hey, for SAS solenoid just re-pin EGR on ecu side and use EGR solenoid to control SAS, it is the same type as "real" SAS solenoid but connector is just different. You need to then of course disable EGR function or you get CEL for missing EGR solenoid (FCA bit 15).
SAS is controlled from pin 5, EGR from pin 6.
Old Jun 2, 2012 | 05:39 AM
  #336
211Ratsbud's Avatar
Donner can you email me a 88586 rom to see if the 3d table will show like that? Since we're both positive the xml is right, how could there be a problem?
Teamcolors30@yahoo.com
Also thanks for your help again!
Old Jun 2, 2012 | 03:44 PM
  #337
Maikumaru's Avatar
http://www.lancerregister.com/showthread.php?t=196839
It is pin 5...my bad.
My Rom is completely custom/ 1 off. The SAS tables were written into the ecu from scratch.
one guy got his to work by flashing like a full jdm Rom onto his ecu.
Old Jun 3, 2012 | 12:06 AM
  #338
211Ratsbud's Avatar
8858 is the audm rom and ive had my ix running on it already, sas routine in place. Tomorrow should be tuning and driving.
Can i measure boost and use a 3 port from the comp housing? Or is that gonna mess up signals/ pulses?
Old Jun 3, 2012 | 12:47 AM
  #339
Maikumaru's Avatar
Ah roger that
You can measure boost from compressor housing.
Old Jun 3, 2012 | 12:59 AM
  #340
211Ratsbud's Avatar
Maik, do you have all of the oe sas tables implemented in your one off rom?
Old Jun 3, 2012 | 01:43 AM
  #341
211Ratsbud's Avatar
donner i clicked the option that allows you to see greyed out maps even if invalid. I got the 3dve table to apear, although it is invalid. What am I missing here?
Old Jun 3, 2012 | 04:41 AM
  #342
donner's Avatar
Maybe you need this scaling:
<scaling name="Percent (128)" units="%" toexpr="x/1.28" frexpr="x*1.28" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
Old Jun 3, 2012 | 08:47 AM
  #343
211Ratsbud's Avatar
I am having the hardest time editing xml with this laptop. if i save it as xml file microsoft compatible it does not work. what program do you edit and save xml's with?
Also I substituted that for the couple bits of scaling listed in the xml already is that proper?
Old Jun 3, 2012 | 08:50 AM
  #344
donner's Avatar
Notepad or Wordpad.
Old Jun 3, 2012 | 09:23 AM
  #345
211Ratsbud's Avatar
Donner, thank you for that! The 3d table shows up perfectly. It took a little patience on my part where to put the stuff you posted, but it just had to be in the xml any where. 8858 sd it is! I just have to figure out the pointers etc, which will come to me eventually, or ask questions and research in the existing threads.
