knock, knock---who's there?
Old Oct 4, 2011 | 05:58 AM
Miller_x's Avatar
So yeah reading about knock for a noob seems to breaking down as such.
1) Real knock - pre-ignition and detonation
2) False knock - something hitting the block setting off the sensor.
Not sure what I am dealing with here.
So a couple questions.
1) Evoscan knock sum - each count is equal to one knock event?
2) When the car pulls 1 degree of timing isn't that equal to 3 counts?
3) Spark plugs gapped at the factory. Should I pull them and ensure proper gap. (Probably good to pull them just to see what the condition is in there (lean, rich, etc on all cylinders)
4) When you do a pull. If I am at a low rpm at say 2000 exactly do I just pound it or roll the throttle on. (The reason I ask this one is it really affects my logs)
5) So I go and do 3 runs my plain 3rd gear pulls have a couple 2's and 3's. But then I do a log from 1-2-3 redlining each gear and I have a couple random 1's and nothing more. Same with a 4 gear pull. Why the difference?
6) When chasing down knock, If my AFR's are right then I am just backing off timing at this point, right?
Thanks for the info. Still learning.
Old Oct 4, 2011 | 07:35 AM
rrkpitt15's Avatar
Lots of things could cause knock, aggressive mivec settings, too much boost for the octane level, bad gas, etc, etc. I was getting alot of inconsistent knock during WOT, so i switched gas stations and it seems to knock alot less now.
Old Oct 4, 2011 | 07:49 AM
Miller_x's Avatar
Yeah, the weird thing is that when I did the other pulls with no or little knock (1's) I had just filled the tank with a fresh batch of 93. Maybe thats part of the mystery right there.
Old Oct 4, 2011 | 08:20 AM
tephra's Avatar
1) no - think of it as a magnitude or loudness indicator...
2) 1 knocksum = 0.35 timing retard, therefore 3knocksum will pull out 1 and a tiny bit of timing.
3) if you want
4) I just go WOT with no rolling into it, sometimes a built motor will knock when you do that because of bad tolerances...
5) because your hitting different load cells
6) what do you consider a right AFR? whats your boost set at? what fuel are you using?
Old Oct 4, 2011 | 08:30 AM
Miller_x's Avatar
Okay. So which is the better indicator of how the engine is running. i.e.. Wound out through multiple gears vs. 3rd gear. Why is 3rd gear the standard. Or is it just a controlled set of load cells for diagnostics.
I am thinking that 11-11.5 is right (but what do I know I'm a noob) My boost is 24 tapering to 21. I am using 93-94
Old Oct 4, 2011 | 08:36 AM
tephra's Avatar
4th gear pulls are the best, they load up the engine properly and run long enough for heat to develop..
trouble is 4th maxes out at 180km/h which is too fast/dangerous for road tuning...
that said I will also do some running through the gears and modify the tune if I see a problem
good stuff ...
Old Oct 4, 2011 | 08:49 AM
Miller_x's Avatar
Yeah 4 gear is pretty fast for sure!
Thanks Tephra
Here are two separate runs both 3rd gear
RPMTimingAdvKnockSumKnockRetard
2062.5390255
1937.5460255
1843.75380255
1500300255
1562.5280255
1562.5210255
1593.75200255
1625190255
1687.5200255
1718.75200255
1750220255
1812.5240255
1843.75240255
1875260255
1937.5250255
1968.75250255
2000250255
2031.25250255
2062.5250255
2093.75250255
2125260255
2187.5260255
2218.75250255
2250240255
2281.25240255
2343.75240255
2375240255
2406.25230255
2468.75240255
2500210255
2593.75160255
2656.25130255
2750101255
2906.2590255
3093.7570255
325050255
3468.7570255
3718.7580255
3968.7590255
4156.2590255
4343.75100255
4593.75100255
4781.25110255
5000101255
5187.5101255
5375111255
5562.5111255
5718.75130255
5906.25130255
6062.5130255
6250140255
6406.25132255
6593.75132255
6718.75141255
6875151255
7000151255
7093.75151255
7156.25151255
7250170255
7406.25170255
7500170255
7562.5170255
7562.550255
7031.25200255
6656.25330255
1843.75360255
1843.75360255
1875360255
1875360255
1875360255
1875360255
1906.25340255
1937.5280255
1968.75230255
2000210255
2062.5210255
2093.75210255
2156.25200255
2218.75200255
2312.5170255
2375150255
2468.75140255
2562.5121255
2687.5110255
287580255
3062.530255
325040255
3406.2550255
3687.570255
3937.590255
4156.2582255
437592255
4593.7593255
4812.5102255
5031.25102255
5156.25102255
5312.5111255
5531.25111255
5687.5111255
5843.75121255
6031.25130255
6218.75140255
6375140255
6562.5140255
6687.5140255
6843.75142255
6906.2570255
6437.5260255
Old Oct 4, 2011 | 09:18 AM
mitsael's Avatar
I had the same problem at WOT with my build block It will knock so we pull timing out and is no more knock but the question is that is this is like a false knock ?? cause my engine build is rated to 680 + and i am only at 521.
Old Oct 5, 2011 | 09:18 AM
qwertykerr's Avatar
Doesn't a stock everything as purchased read levels of knock as well?
fostytou's Avatar
EvoM Community Team
Your only real answer between real / false knock is det cans or actually listening to the motor yourself. If you have it strapped down and can stand next to the engine bay it sounds like a hammer hitting the block, however that is not always easy for an untrained ear to hear.
There are other methods, but once set up that is the fastest and most reliable way to tell.
Old Oct 5, 2011 | 10:04 PM
sstevojr's Avatar
You need a WB. Could be chocking on the fuel and giving you that slight knock (known to happen).
And FYI, if you can hear knock it's too much. I've only heard it a couple times, sounds like a fast pinging (kinda like when you get home on a cold night and your exhaust starts cooling off quickly; only at a much faster tempo). Logs showed ks of 30+ on a really steep grade at low revs (easiest way to get knock)
Old Oct 7, 2011 | 08:39 AM
Miller_x's Avatar
Can you force knock?
Like when you are driving at say 60-70 MPH and then floor it(WOT) still in 5th. Would the load on the engine in that gear and being under the power band cause a knock situation on an otherwise well tuned car.
Old Oct 7, 2011 | 09:39 PM
chetrickerman's Avatar
Veteran: Army
yes.
too much timing, too much boost, ****ty fuel, improper air/fuel ratio all cause knock
Old Oct 11, 2011 | 06:16 AM
Miller_x's Avatar
Originally Posted by chetrickerman
yes.
What I am refering to is high load on low rpm. I think that has little to do with what you just mentioned but more the fact of the stock turbo size + mivec timing creates spool with slower moving pistons. There for creating a knock situation.
There fore when driving if you don't down shift and floor the car you will create a high load + low rpm = overpressure and knock.
Yes or no?
Old Oct 11, 2011 | 01:14 PM
tscompusa's Avatar
ive noticed some roms have better support then others when it comes to the knock filter tables.
for example: 53050109 has everything in its xml..
Knock Sensitivity Load Threshold and
Knock Background Noise Multiplier
those are the only 2 tables you should need when adjusting sensor sensitivity.
and i see on this rom: 52680122
it has nothing .. none of these tables.. except it has 3d tables that are titled
knock filter #1 through 5
are the 3d tables named knock filter actually real or are they mistyped table names?
and do we know the load threshold address and multiplier for the rom i mentioned above? 52680122
Reason I ask, is because i have a 2008 time attack evo X that has prototype BC cams in it and it knocks just driving around and everything is 100% conservative and everything's all good in the car.. these damn cams are just so aggressive..
we get a clean pull every now and then but once it start at spool area it just creates the knock train and sensor becomes overly alert and from there everything goes to crap.
we put in c16 race gas also.. it is 100% false and confirmed with det cans and race fuel.
i pm'ed tephra but im sure he gets a million pm's.
