EvoScan J2534 Read Error - 16
Old Jun 9, 2014 | 06:50 PM
  #61
CDrinkH2O's Avatar
Originally Posted by jrainwater
Ecuflash 1.42 doesn't work with tephra v7 tho correct??
It works fine for me.
Old Jun 9, 2014 | 09:20 PM
  #62
TJung's Avatar
Of course it works
Old Jun 9, 2014 | 10:01 PM
  #63
jrainwater's Avatar
Good to know but I still dont understand how using a different version of ecuflash makes the DTC and actuator functions work with an openport 2.0 on evoscan.
Old Jun 9, 2014 | 10:08 PM
  #64
codgi's Avatar
Different versions install different drivers if both programs use the same driver then that's your explanation.
Old Jun 9, 2014 | 10:10 PM
  #65
jrainwater's Avatar
Originally Posted by TJung
I had the same problem with Evoscan 2.6 and Ecuflash 1.44. I just back to Ecuflash 1.42 with it's old drivers and problem gone. It;s related with ftdi drivers.
Lol @ of course you can. This thread isn't even about v7 so I should be more clear, maybe you didn't read the whole thread. So you are saying that you can use evoscan and a 2.0 openport to read and clear DTC's as well as activate all the actuators in the bottom right hand corner of evoscan simply by installing 1.42 instead of 1.44???
Old Jun 9, 2014 | 10:14 PM
  #66
jrainwater's Avatar
I wish it was that simple. If it was Hamish wouldn't be rewriting evoscan to work with the new 2.0 firmware, it isn't the driver itself. It's the firmware and the way evoscan recognizes the firmware that causes the j2534 driver to error. I don't see how using 1.42 changes the hardware's firmware, because it doesn't.
Old Jun 9, 2014 | 11:47 PM
  #67
05VIII's Avatar
so whats the deal is there a fix? really annoying to plug in a scan tool to check lights
Old Jun 10, 2014 | 02:22 AM
  #68
TJung's Avatar
I tell You my story... I have Evoscan 2.6 and Ecuflash 1.42 and OP 2.0 and Win XP laptop. Everything worked great until I updated Ecuflah to 1.44. Then I had this J2534 problem. I reinstalled my WinXp, because deleting ftdi drivers wasn't possible in the other way. I installed again Evoscan 2.6 with Ecuflash 1.42 and again everything is working great . Really.
The problem is with ftdi drivers. They are really hard to reinstall.
Old Jun 10, 2014 | 02:59 AM
  #69
Broke4speed's Avatar
The issue is with the way Evoscan 2.6 works with 1.44. ECUFlash is a constantly updated program, that's supported by it's developers, and EVOScan 2.6 was made in mid-2000...so why would someone reduce the functionality of their flashing program just to use a really old version of logging software that is buggy at best?
The OP2.0 doesn't even use FTDI drivers, only the 1.3.
Old Jun 10, 2014 | 04:36 AM
  #70
evoscan's Avatar
Silver Sponsor
@Tjung the ftdi drivers are actually very simple to uninstall/reinstall. there is a program on the ftdi website called FTDIclean. which all it does is uninstall the driver from device manager and deletes the .ini file from the windows/inf folder.
@broke4speed the issue is very simple.. it has to do with the J2534 firmware 1.15.4126, it now returns code16 when there is a timeout. it used to return code9 timeout. it seems like ecuflash v1.44 because v1.44 distributes J2534 firmware 1.15.4126 to your openport 2.0 hardware automatically when you start it and plug in the openport2.0, I'm fairly sure going back to an earlier ecuflash will have no effect. Either way a timeout is a timeout, it ain't gonna help return a DTC code in any case. EvoScan v2.6 had a good DTC codebase. Since then more vehicle support has been added to the DTC, and created a bug by mistake in v2.9. I am working on a DTC op2 bug fix this week.
it must be a timing issue, because the same DTC code is used for openport 1.3U and it is fine. I know the 1.3U is faster at about 180 samples per second and the openport 2.0 about 110samples per second. it could be that. I'll find a work around. I'll keep you posted. -Hamish.
Old Jun 10, 2014 | 06:19 AM
  #71
TJung's Avatar
Thanks. I'm not huge computer freak, so I didn't knew that 😉
Old Jun 10, 2014 | 06:57 AM
  #72
jrainwater's Avatar
See I told you that he was working on fixing it right now thanks Hamish. There's a ton of time that goes into fixing this on his part and I am very appreciative of his efforts. I also know there are a ton of people with 2.0 cables that use evoscan with their pre-X Evo's that are going to really appreciate this update as well. Shoot, if he can make my openport 2.0 live tune as well (like the 1.3 cable does) I would even be willing to pay for evoscan again lol. "Hint Hint Hamish"
Old Jun 10, 2014 | 03:56 PM
  #73
Considering this thread was started in March of 2013, and I've found other threads dating into late 2012 with the same issues...I'll only believe it when my legit 2.9 tells me there's an update. I'm sure you're a busy guy, but 12+ months of inaction is kinda hard to swallow.
Old Jun 10, 2014 | 05:43 PM
  #74
jrainwater's Avatar
I don't know if Hamish wants his personal business aired in public and if not I apologize before hand but in his defense he does have a newborn baby at home right now, someone reliable told me that little tid-bit. And he is choosing right now to finally fix this issue because of this thread that I started back up if I had to guess why its finally happening. He wants to make it work, he has the know-how and the knowledge to make it happen AND he is dealing with a newborn baby on top of everything else so let's give him some time and I feel pretty confident from the emails he has been sending me that he is going to finally fix this issue. I've even received a beta copy that fixed the j2534 timeout error but was having difficulty communicating with the ecu. I'm pretty sure he is close but since I know he is working on it I'm going to be patient for now
Old Jun 10, 2014 | 10:51 PM
  #75
codgi's Avatar
Actually had that been the issue that is exactly how you solve the problem. You would adjust the program itself to be able to handle differing versions of the driver and even now knowing what the problem a correct fix is still going to need to be able to work with those differing versions so you don't only have it work with the newer version. But you're right I just talk about this stuff on the internet I don't do it for a living or anything.
