88590015 won't show fuel trims?
Old Apr 5, 2014 | 12:53 PM
211Ratsbud's Avatar
It opened up as a standard rom for me as well.
Old Apr 7, 2014 | 09:13 AM
fostytou's Avatar
EvoM Community Team
Are you running the O2 simulator code from mrfred? I would think the trims would still be in effect, but I can't quite remember if you need to log a different location. With rear O2 disabled it sounds like someone was either trying to prevent a no-cat CEL or doing simulation.
Doing a bit-wise comparison of your periphery working to not might make the changes more obvious too.
If someone who has most of their mods loaded into ecuflash can do a table comparison between your working ROM and non-working ROM it might be easier to identify. Asking the last tuner if possible could be helpful as well if they are available.
Also - make sure you are logging the right thing for trims in evoscan since formulas have been known to change. It sounds like you have that covered though.
Good Luck!
Toekneee!
Aug 24, 2015 07:01 PM
ridenrunwv
Aug 20, 2015 07:19 AM
kaj
May 27, 2015 06:11 PM
GeoMitsu
Nov 6, 2013 01:16 PM
nicolassabra
Sep 19, 2013 04:02 AM
