Ignition Retard Limit for Evo 8
See the 96530006 entry here: https://www.evolutionm.net/forums/ec...l#post11557514
I have a JDM Evo 8 with the 96530706 tephra ROM.
I am trying to retard my timing beyond the stock lower limit (-10 degrees). I have added the following patch code to the 96530706 tephra XML.
<scaling name="TimingMUT" units="degrees" toexpr="x-20" frexpr="x+20" format="%.0f" min="-20" max="60" inc="1" storagetype="uint8" endian="big" />
<table name="Ignition Retard Limit" address="1813d" category="Timing" type="1D" level="2" scaling="TimingMUT" />
<table name="Ignition Advance Limit" address="1813f" category="Timing" type="1D" level="2" scaling="TimingMUT" />
In the tables I changed the ignition retard limit to -20. Went ahead to the map and changed the timing in the respective timing cells to -20 as well. Flashed the ROM. Logged using evoscan. The lowest timing retard that I can see is still -10.
What am I doing wrong here.?
mrfred
Dec 11, 2009 11:24 AM
