Help needed with 52370024
Old Nov 14, 2017 | 06:59 AM
raasfaas's Avatar
Hey guys, it's been years since I've been out of an Evo (had a IX MR) so please bare with me. I'm having a little trouble logging my 08' JDM SST (523700224). I've read through a bunch of threads and followed the steps but still am getting some weird values in evoscan. I copied the following lines of code to my xml file:
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f58d" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ad91" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ad96" scaling="Hex16"/>
I've also made the changes in ecuflash, but when I open evoscan and start logging all the data is off (I'm thinking that I don't have the correct data.xml for evoscan which I tried hunting down on goldenevo's site but that's down).
If I get the correct data.xml should I be okay to log or am I missing something else?
Thanks in advance for any help.
Old Nov 16, 2017 | 03:46 PM
raasfaas's Avatar
Anyone kind enough the share their data.xml (hopefully that's the problem).
Old Nov 18, 2017 | 01:41 AM
crimson red's Avatar
Hi,
Did you change the tables correctly like below?
Old Nov 18, 2017 | 03:32 PM
raasfaas's Avatar
Thanks for the response, yes I do believe I made the correct changes, I think the problem might lie with my evoscan. Is there any patching that needs to be done to evoscan to be able to log?
Old Nov 18, 2017 | 09:46 PM
There are no patches. No needs for logging with mode23.
Looking at your image, it seems that there are two sets of mode23 tables.
a)IFMode 0x05 0> 0x23 #1, IFMode 0x05 -> 0x23 #2, DoMode 0x42 -> 0x52.
b)Mode 23 - IFMode 0x05 -> 0x23 #1, Mode 23 - IFMode 0x05 -> 0x23 #2, Mode 23 - DoMode 0x52 -> 0x52
Make sure the tables have correct addresses and delete either a) or b).
After surely flashing modified rom, use latest version of evoscan.(v.2.9.0100)
Before trying mode23, can you take a correct log with "EVOX CAN MUTIII"? If you can't, make sure that OpenPort 2.0(J2534/CAN/EvoX) selected, CAN 2006+(EvoX) checked.
If you can take a correct log with "EVOX CAN MUTIII", check these points below image showing:
Good luck,
Old Nov 20, 2017 | 06:13 AM
raasfaas's Avatar
Thanks Crimson, I'm pretty sure I made the correct changes to the xml file but I'll start over from scratch with the original rom and follow your steps, I'll report back.
Old Jan 1, 2018 | 06:47 AM
wreckleford's Avatar
Did you get through with this? I have a bunch of data.xml files you can try.
Old Jan 3, 2018 | 04:44 AM
400s's Avatar
Move over to raxfast logging https://www.evolutionm.net/forums/ec...t-logging.html
You will have better resolution in the logs...
ill-luzion
20
Nov 23, 2007 11:07 AM
LV///R
17
Jun 17, 2006 08:30 PM
LIFER
45
Dec 11, 2005 08:06 PM
