Trying to live tune 55570306 V3 and keep getting this error message. Anyone help solve the issue?
Can you open and edit your 55570306.bin(or .hex) by ecuflash?
Please attach your TephraXMOD-55570306.xml, 55570006.xml, and 55570005.xml in your 'ecuflash/rommetadata/mitsubishi/evo/' folder to your post. We can check them.
Just in case:
Before using LiveTuner, you have to install TephraXMOD-55570306.xml into your 'ecuflash/rommetadata/mitsubishi/evo/' folder so that ecuflash can open and edit your 55570306.bin(or .hex).
Okay. The scaling address of the table "Battery Voltage" and the table name for "map based load calc" are incorrect.
Follow the following. The issue would be fixed.
1. In 55570005.xml, change the address of the table "Battery Voltage" from 6536A to 61082(as below).
2. In TephraMOD-55570306.xml, change the name of the table "MAP based Load Calc #1 - Hot/Interpolated" to "MAP based Load Calc #1 - Hot/Interpolated 2010"(as below).
It should work.
I think there is a possibility that the old (unmodified) files still exist somewhere and been loaded.
(If the old files remains, even if the names are different, it may be read by LiveTuner instead of new files.)
By the way, if you can attach your rom, we can check it just in case. (For example, if you return the tuned content to the stock state or clear tuned maps, we will not be able to see the tuned content.)
It should work.
I have done many clean installs. No old files left. Rom attached.
Result is like below pic. LiveTuner works well to your rom with the corrections I have posted. Issues of the definitions for your rom were corrected properly.
As far as seeing the result, I have to say that there seems to be some kind of problems somewhere in the installation state of your ecuflash and LiveTuner. it seems to me that your ecuflash is still reading some old definitions from somewhere.
I can get to that if I delete that line in Tephra Mod.
The definition issue of 55570306, 55570005 has already been resolved, so if there is a problem remaining, one or more of other definitions may be affecting.
If you can't find problems that only happen on your PC, though you can't live tune the deleted map, but I think it's okay.
Or, if you can archive all the contents of your ecuflash/rommetadata/ to a .zip with keeping its directory tree and attach it, the cause may be found. Will you do it?
I tried another fresh install and it does the same thing
If same problem occurs after a clean installation(and replacing TephraMOD-55570306.xml and 55570005.xml), how about archiving to a .zip all the contents of ecuflash/rommetadata/ of that ecuflash as it is and attaching it?
