Peak boost lean issue
Old Nov 24, 2019 | 07:25 PM
nor11384's Avatar
FCOTM Winner
Ok guys so did some wot pulls and noticed this. So when the car hits that max boost after it spools up the afr is reading 12.8 - 13. Ive tried to richen it up but it seems to not be doing much. I just gave it fuel from 4 - 5k rpms in rpm ve. Any ideas? Here are some pics of logs etc. Also, you can see in the logs when i go wot or 100% tps the load reading goes out of wack. Idk why its doing that.
Old Nov 24, 2019 | 07:30 PM
nor11384's Avatar
FCOTM Winner
Here is a log from a year ago. Notice the difference. Nothing changed on the map. Why is it doing that?
Old Nov 25, 2019 | 01:40 AM
rjwkerkhof's Avatar
What are your IAT readings during this issue?
Last edited by rjwkerkhof; Nov 25, 2019 at 01:44 AM. Reason: Misread and therefor misanswered :)
Old Nov 25, 2019 | 10:34 AM
nor11384's Avatar
FCOTM Winner
Here are the pics in order with iat selected. The one from a year ago the temps were hotter. The other two from this week it was colder but it seemed the colder the temp the richer the afr on these last 2 runs. I was looking over some ait tables and tried messing with a a bit but dont understand it. It does make sense for it to be ait related. I mean i dont see what else it can be. if there was a way to control afr based on ait it would help alot.
Old Nov 28, 2019 | 09:16 AM
nor11384's Avatar
FCOTM Winner
Nothing? Anyone else?
Old Nov 28, 2019 | 10:52 AM
rjwkerkhof's Avatar
Sorry Nor, just hadnt had the time to have a proper look on it. Will get back to you asap
Old Nov 28, 2019 | 02:21 PM
nor11384's Avatar
FCOTM Winner
Ok no prob bro. I appreciate it.
Old Nov 29, 2019 | 03:50 PM
nor11384's Avatar
FCOTM Winner
So ive been logging air temp and recently found out im supposed to log maf air temp scaled which is mut11. This is supposedly what the ecu sees to make its adjustments. So here are new logs. Also, you can see my knock issue around 100 load 3 - 4k rpms.
Old Mar 23, 2020 | 05:29 PM
elmanre's Avatar
Did you manage to solve this? Same happens to me at WOT peak load, changes in the table does not makes any difference.
razorlab
Sep 14, 2019 07:23 AM
ouminan
Jan 21, 2010 08:19 AM
leecavturbo
Jul 13, 2009 11:10 AM
vgknight
Oct 19, 2008 03:48 PM
recompile
Jul 8, 2007 05:42 PM
