MAPcalc based only load, load fluctuations
Old Sep 25, 2020 | 10:38 AM
eTiLiKo's Avatar
Car is on tephra V3 (53050312), MAF scaling to 65536 everywhere because the inlet pipe is very big, and the MAF at low rpm is very unstable, So it is a MAP based Load car now.
Screenshot of actual MAPcalc and Load logged in evoscan. Have someone seen something like this before? The load drop between 4500 and 4800rpm, Haven't tried at high rpm yet.
Old Sep 26, 2020 | 02:34 AM
eTiLiKo's Avatar
6000rpm run
Old Oct 6, 2021 | 10:14 AM
eTiLiKo's Avatar
One year later and another turbo setup, same problem, never solved. This is a WOT pull, my mapcalc tables past 110Kpa are exactly the same , MAF tables to 65536 everywhere.
I dont understand! The pronlem is very visible also in part throttle runs
Old Oct 6, 2021 | 10:39 AM
RazorLab's Avatar
Probably your IMAP calcs. I bet if you log IMAP you will see spikes there that bring down the load.
If so, the fix is easy: https://www.evolutionm.net/forums/09...-solution.html
Old Oct 7, 2021 | 02:14 AM
eTiLiKo's Avatar
Thanks a lot mate, it seems that I need "Load multiplier end when TPS decreased by % (hysteresis)" for 53050012
EDIT :
FOUND manually comparing roms, and it solved all my problems, Thanks a lot
<table name="Load multiplier when TPS increased by %" category="Load" address="546d4" type="1D" scaling="Throttle %"/>
<table name="Load multiplier end when TPS decreased by % (hysteresis)" category="Load" address="546d0" type="1D" scaling="Throttle %"/>
Old Oct 7, 2021 | 06:57 AM
RazorLab's Avatar
EDIT :
Great, glad that worked! I always set those first in all my tunes.
ed1380
Jul 13, 2015 01:02 PM
mrfred
May 12, 2015 05:29 PM
tephra
Dec 10, 2011 05:50 AM
crimson red
Jan 7, 2010 08:30 PM
llabmik2
Feb 7, 2007 11:05 PM
