Why can't I get mo boost
Old May 31, 2021 | 02:43 PM
nglett's Avatar
Its probably because I'm not understanding something correctly and have something off in one of my boost tables but I can't build anymore boost then spring pressure. I running a 59580304 rom with a Garett GTX3071r gen2 turbo with full exhaust, Omni 4 bar, MAC 3 port ebcs and supporting mods. My (Omni 4 Bar Boost) Boost Target #1A,B,2 is set to 25psi. The (Turbo) Reactive Solenoid Base WGDC Map #1A, B, 2 are set to 99 and (Turbo) Reactive Solenoid Error Correction Interval is 7. No matter what I change or how I change it the boost stays the same. I was using a Tactrix 3 port ebcs with 5/32 hose and changed to the MAC with 7/32 hose. Port 1 (right) goes to the intake tube, between the air filter and turbo. Port 2 (left) goes to the IWG and Port 3 (center). Log from the 3rd gear pull is attached.
get pressure from the turbo outlet adapter.
Old May 31, 2021 | 03:49 PM
RazorLab's Avatar
You have it installed incorrectly.
Port 3 goes to the nipple on the compressor outlet
Port 2 goes to Actuator
Port 1 goes to intake nipple
Also, make sure you have the brown plug connected.
Old May 31, 2021 | 04:02 PM
nglett's Avatar
Thanks for the quick reply... port 3 is going to the compressor outlet adaptor. Poor proofing 🤦‍♂️
I have it connected to the black ebcs connector though. The Tactrix ebcs w/ pnp harness connects to the black plug. Now i feel like an idiot, never thought to verify the plug.
Thanks again for the help
Old May 31, 2021 | 04:46 PM
RazorLab's Avatar
yup the incorrect plug is your biggest issue. Be sure to bring those wgdc tables wayyyy down or you are going to overboost like hell!
Set correction interval to 1 as well.
Old Jun 3, 2021 | 08:04 AM
nglett's Avatar
It was 100% the plug. Dropped the tables down to 40 on the high end and end up at 53 with a 20# wg spring.
I set the correction internal to 1 as recommended. Does entering a value of 1 offer the fastest or the most amount of wastegate correction and what is the range?
Old Jun 3, 2021 | 08:10 AM
RazorLab's Avatar
1 sets it to the fastest interval of WGDC Correction. The actual percentage amount of correction is set in the Boost Error Correction table.
The standard 7 is too slow once you start making decent power.
03Ev0luti0n
Aug 4, 2015 12:32 PM
hachansoo0413
Aug 24, 2012 08:12 AM
fknchristoph
Apr 12, 2011 11:24 AM
evoniners
Feb 7, 2009 07:06 PM
sba
Apr 8, 2008 05:07 PM
