Ecuflash using mapsensor w/o piggyback possible?
Although the original ecu is designed for mass air is it possible to develop a code for ecuflash that will allow the stock ecu to accept a map sensor and iat sensor without a piggyback?
Once the entire rom is reverse engineered, Its certainly possible for someone to do it.. Will it happen? Well, nobody can say. I do have to keep reminding people that Speed Density is just not all that great.. having a MAF makes for much better drivability.. At this point your probably better off buying something that can offer the feature to convert it to a MAF Karmann signal..
So for example just purchasing a maft pro to convert to map and leaving settings at zero and just tuning in ecu flash. |
Yep pretty much..
Target AFR Target AFR For alky Fuel Trim for alky Can make fuel adjustments without a laptop etc... ecuflash+maftpro is an awesome combo {thumbup} |
You have to ADD a lot of fuel with the conversion. |
Originally Posted by TTP Engineering
This is how our shopcar is tuned via ECUTEK reflash.
You have to ADD a lot of fuel with the conversion. Why is that, does converting over to map make the car run leaner? |
