1.28 now available
Thanks for the updates Colby. :)
P.S. Looks like you beat me to the post. |
are there any changes that will affect the EVO 8 in the 1.28 release??? just want to know if i need to update
i haven't found any
Oh well i dl'ed it anyway
Where can I go to download this version in .zip format? The posted version on OpenECU is in the .rar format.
A better question is where can you download winrar... www.download.com
Oh yeah! That's what I'm talking about bro! I'm downloading the drivers as we speak. Thanks.
NP. Winrar is a great utility, it handles almost every type of file compression.
Right..... so are there any updates for the 8 or what? Do i need to get it?
Its in your best interest to update to the newest version, there were some changes to the bootloader name and definition files that WILL eventually bite you if you don't..
Fair enough...... but can someone please elaborate on said changes?
Originally Posted by Evoscan
Data Logger Features: EvoScan v0.8
UPDATE: 1) Increased Datalogging Speed! - Added Log To File option - Added Log To Screen option - Added Logging SuperSpeed option To get maximum speed - Disable Log To Screen, and Enable Logging Superspeed. Less effect is noticed on 2000ghz laptops with a/c power, but slower laptops or laptops running off the battery benefit a lot of speed! 2) Increased Stability of start/stop datalogger. 3) Added AYC Info to Data.xml 4) Added DTC Fault Code Info to Data.xml 5) New Log File Format! - Thanks for all of your feedback on this - results now cross-tabulated with easy to use LogId/Date/Time/Seconds 6) Altered DataItem Calculations: - Increased accuracy on FuelTrim calcs. (Fuel Trims: <100% (lean) >100% (rich) ) - Fixed accuracy on Timing Adv calc. - Added DataLog="Y" to xml file for default datalogging items ticked. - Implemented Multiple ECUs to XML file. 7) Added DTC Trouble Code Support - DataLog Active/Stored Fault Codes - Retrieve EFI Fault Codes - Clear EFI Fault Codes Added simultaneous WideBand SerialPort Logging Support (untested) 9) Added View Log Files Menu Item 10) Added ABS Info to Data.xml |
Originally Posted by TTP Engineering
Thank u sr.! |
