EVO IX Injector Scaling
I have downloaded an EVO IX base map and you do not seem to have access to the injector scaling. I also downloaded an EVO VIII base map and injector scaling is accessible. Is this something that is still being developed?
Seems to be there on JM8859 with ECUflash 1.28.
Have a look on the Evo 9 forum on openecu.org
It shows up on all my IX roms.
Girlie |
I tried increasing or decreasing the value and the program crashes... anyone else getting this?
what ROM are you loading, and what field are you editing to cause a crash? What ROM XMLID is the file?
http://forums.openecu.org/viewtopic.php?t=276 |
you have to be more specific, we need to see YOUR rom, and what exactly you are doing at the time it crashes.. Even if you have more than one window open or map loaded..
How do I find the XMLID? I've loaded my stock 06 MR rom in .hex format. The Internal ID is 88590013 and the Memory Model is SH7055. I don't know if that helps. It crashes when I try to change the Injector size scaling. By default the value is "<.." doesn't seem like its even a valid numerical value? |
What you have described is the reason why I started this post. The Evo IX map I have shows "<.." for the injector scaling. However, when I downloaded an EVO VIII map it shows the injector size.
Have you tried changing the value though? When I do that it crashes the program. Does that happen to you? |
It does not crash, it just does nothing as it still retains the value "<.."
Bump... can anyone help with this? Thanks in advance
