-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   welcome me to shouldn't be (https://www.evolutionm.net/forums/ecu-flash/253657-welcome-me-shouldnt.html)
nothere Feb 25, 2007 10:35 AM
guess I shouldn't be ecuflashing because ....
I can't get my ecu read from the ecuflash program. Every attempt ends in some problem, misread kernel, can't read ecu, etc. Sometimes I can retry and get a little farther down the list only to fail on another item.
tried installing and reinstall ecuflash
I get a number of clicks from the car during the upload attempts, and have an ecu-plus connected, could that be an issue?
anyway, " Hi " to all the other shouldn't be doing this guys.
Deepseadiver Feb 25, 2007 10:59 AM
I sometimes feel the same way!
codgi Feb 25, 2007 11:01 AM
Hmm that sounds odd....I think MJ runs both ECU+ and flashing just not sure if he runs them at the same time or not...what is the exact error it gives?
nothere Feb 25, 2007 11:37 AM
error sending init sequence 3
error sending kernal size
no response to any know code
could not read ecu
looks to me like a poor connection that fails randomly, or is interfered with by noise.
CBRD Feb 25, 2007 11:44 AM
make sure u have ur cable plugged in before you start the program.
I turn the car on,
plug in the cable to the car, both connectors
then plug into my laptop
then open ecuflash.
cb
nothere Feb 25, 2007 12:11 PM
well that exact routine did help some, I got to
rkrv: can't read response payload
ECU memory read failure
can't read image
no response to any known code
laakness Feb 25, 2007 12:13 PM
Do you have a mini-battery? Insufficient power can result in bad reads/writes.
Try hooking a battery charger up while doing it.
Evo442 Feb 25, 2007 12:24 PM
was it reflashed previously? Perhaps Malibujack's ecuunlocker could help...
nothere Feb 25, 2007 01:54 PM
flash by Al some time ago, so I don't think that is an issue.
Power may be, the newly installed wideband has to stay hot, a few leds in gauges and a converter for the laptop, that might be the culprit.
roger smith Feb 25, 2007 02:03 PM
I think I had this problem and might have your solution.
The ECU+ has a jumper on it to enable ODB2 data reading. If that is enabled in the ECU+ then tactrix cable becomes useless because the ECU+ prevents ODB2 access.
Write an email to Tom about the ECU+. I'm not sure if I remember correctly but if you can take out the ECU+ board then you'll see a jumper that has an ODB2 label, you'll have to take the jumper off of just jump one of the pins rather then two.
KartaRailed Feb 25, 2007 02:04 PM
Al locks his maps.
RazorLab Feb 25, 2007 02:11 PM
It's the ECU+, you either need to have the OBD2 jumped change like Roger Smith said above or remove it when flashing the car.
C6C6CH3vo Feb 25, 2007 02:19 PM
Just be persistant, cautious, observant, and experimental. Don't be afraid to uninstall/reinstall. Make sure car battery is charged, dont plug and unplug without ign off, and dont ever test your tune without monitoring knock live
CBRD Feb 25, 2007 02:21 PM
hook up a battery charger, see if that helps.
cb
chaotichoax Feb 25, 2007 02:39 PM
Originally Posted by KartaRailed (Post 4018981)
Al locks his maps.
yes he does so dealers can't erase them
go to activematrix.com and use the ecuunlocker download there
