A Virgin Logger's first log (impressions+questions)
After performing the 2 byte load mod, loaded up the laptop and drove from one house to another...took a log of the whole trip. My impressions and results are as follows:
1. I didn't realize through the forum posts that Evoscan's boost value is a !little! bit off. You should have seen my face when I thought I hit 47 PSI...:eek: :lol: 2. The only case of knock throughout the whole endeavor was during passing... hit knocksum 7 and set off the alarm... But I can't figure out for the life of me why. TPS read ~40%, load was scarely 130, air, egt, timing advance, all normal. Possibly related to using a turn signal? 3. ECUload and 2byte MUT values suprisingly close...more so than I thought they should have been. only departed by maybe 2 points in most spots, of course except for 160+. Now I'm off to take some controlled acceleration runs. I learned a lot in that first log. If anything, I hope this experience helps some other fearful loggers take the leap. |
ECULoad and 2 Byte Load will be similar until it clips at 160 (for ecuload)
Calculated load (Loadcalc in Evoscan, LOAD in Mitsulogger) is where you probably see about a 10% difference depending on several factors. |
After a few runs, I decided to try and remove the boost taper... I read on here Boost limit values just all had to be set even (at 255) however doing this had 0 effect on load, acceleration, knock...etc...
I'm positive I flashed correctly and did re-check the values. Is this not the correct value to modify? |
Originally Posted by Titanium
(Post 4166442)
| All times are GMT -7. The time now is 12:52 AM. |
