-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   can't read ECU, need help (https://www.evolutionm.net/forums/ecu-flash/284827-cant-read-ecu-need-help.html)
kittio Jul 22, 2007 08:20 PM
I've used ecuflash for a month and got some good experience until my last map. I'm not sure what mistake I did cuz I can't connect to the ECU anymore, the log said "(FFFF) unknown code" which I can't read and write to the ECU. Someone knows how to fix it?please help
Thx
PS 1. my car is Evo 9, JDM
2. evoscan is still working.
3. My program n cable can work with other evo.
Vishnu_Evo8 Jul 22, 2007 08:27 PM
ecu got locked? how many times have you flashed it?
kittio Jul 22, 2007 08:31 PM
less than 10 times
Ph3n1x Jul 22, 2007 08:40 PM
Uninstall and reinstall ECUFLASH.
Reflash your base stock map back on it.
kittio Jul 22, 2007 08:52 PM
I reinstalled it but still can't flash the base map to ECU, the log said "unlnown code".
awddyno Jul 22, 2007 08:55 PM
I had the same thing happen. Usually you can only hear one click when you start to read the ecu. But I kept getting 2 clicks then it throws the unknown code. I tried running the unlocker in the back ground but still the same issue. Then after the 4th or 5th try it just worked. ????
Ph3n1x Jul 22, 2007 08:59 PM
Unistall, Restart the machine, Reinstall, Then insert cable and try.
kittio Jul 22, 2007 09:22 PM
yes, the same problem, hopefully will work again as you.:beer:
will try it, thx {thumbup}
burgers22 Jul 22, 2007 09:25 PM
Hi
Evo Ix s are known to have a problem with low battery voltage causing a failure to connect. Also if the Tactrix cable has some loose pins this will cause the same problem.
MB
kittio Jul 23, 2007 12:02 AM
tried 2 times and the result are the same.
kittio Jul 23, 2007 12:09 AM
Originally Posted by burgers22 (Post 4565798)
Hi
MB
the battery is still OK, 13.93V, and the tactrix cable is OK too. I will bring mycar to Mitsubishi dealer for checking the two conector, OBD and the small one.
thx,anyway
burgers22 Jul 23, 2007 12:17 AM
That looks like quite a high battery voltage. Did you measure that with the engine running?
Did the last map you flashed come from a tuner or another source? Have you tried the ECU unlocker program?
MB
kittio Jul 23, 2007 01:06 AM
MB
No, the last flashed was fq map. BTW how do I get the ECU unlocker programme?
Thx
burgers22 Jul 23, 2007 01:12 AM
Did you flash the whole ROM ( which is a bad idea ) or just the maps?
ECU unlocker at www.aktivematrix.com
MB
kittio Jul 23, 2007 01:17 AM
the whole ROM, I asked my bro to copy only the map but he did flash the whole.
