let's see your maf scalings
ok, people with aftermarket intakes, if you don't mind let's post up your maf scalings and smoothings. please also list your intake and filter brand.
wow, doesn't look too different from stock. how's it run Phenix_fyah?
Close to 100 Mid and Low Fuel trims....Anything more or less will give +/- Trims.
kool
anyone else?
The other day I ran the stock scaling just to see where the differences are and the mid trim dropped from 100 to 80 and the WOT AFR dropped from 12.4 - 12.4 (4500 - redline) to 12.0 to 11.2
HKS RS Does anyone know the impact these maps have on how the ECU decides what TAR unit to use with the knock filters? If so, then by just changing an intake the knock sum may be off either way. |
wow, must have screwed the maf quite a bit!
| All times are GMT -7. The time now is 07:10 PM. |
