Can't get Load to hold flat
Well I posed a while back about having my load dip. After a bunch of posts it seems that the load dip was being caused by unstable boost. In fact we saw that load nearly matched the boost curve exactly.
Well I got the boost curve to be more flat but load still seems to dip a lot. Green is load, light blue is boost. My timing is dark blue, which seems to be pretty flat so I don't think that would cause it. MIVEC maybe? http://www.skidmore.edu/~a_blaker/Mi...%20Dipping.bmp |
The boost plot seems unstable....maybe a boost leak somewhere?
Your load only spikes to 190? That seems really low...what boost are you running?
Originally Posted by urBan_dK
(Post 5033000)
the picture is not loading for me for some reason..
lets see the VVT map ?
It had been one of mine and might still be. You could put it back to stock or to a JDM RS map and see if that has any effect on the curve. The only other thing that I can think of and have seen alot is if it is mine and you switched to the NLTS rom or something make sure it is still scaled to 8K like it needs to be whether you rev that high or not.
Have you rescaled your maf by any chance? Load is basically a mass airflow/rev. So, anything that may alter airflow readings can alter your load level.
Eric |
Not sure on your load dip, that is weird. Your boost spools nice and stays flat though, are you using the GM 3-port? If so can you post your WGDC table?
Originally Posted by JohnBradley
(Post 5034359)
I did remove the box of 28.8 @ 4k and put it to 26.4 in an attempt to smooth load out, although it did not seem to work. I will try the JDM MIVEC next. |
Originally Posted by l2r99gst
(Post 5034378)
Eric |
Originally Posted by merkzu
(Post 5034383)
I will post up table, give a few min. |
Originally Posted by mrfred
(Post 5033521)
That's a pretty darn flat boost curve. Load is basically MAF/RPM. Might be useful to try logging 2-byte air flow along with the other items.
(Post 5033000)
Originally Posted by dudical26
(Post 5034705)
No i did not rescale, I have a Buschur MAF Pipe and filter if that matters.
Once you post a new log with Hz values, we can see what areas of the MAF table may need adjusting, if you want to go that route of fixing the load dip. Eric |
| All times are GMT -7. The time now is 11:07 PM. |
