MWDC / BDEL question.
05 Non-MIVEC
What's the difference between... Max Wastegate Duty Cycle 1 Max Wastegate Duty Cylce 2 Max WastEgate Duty Cycle 3 and Boost Desired Engine Load 1 Boost Desired Engine Load 2 Boost Desired engine Load 3 When I change these for controlling boost with the factory solenoid, do I have to change all 3, or can I just change #1 of MWDC and # 1 of BDEL? |
Table #1 is the main table. Table #2 is not used by the ECU. Table #3 is used when the car exceeds the "Boost Limiting Vehicle Speed".
Originally Posted by mrfred
(Post 5049824)
From my previous work. I'm sure about #1 and #3, but not entirely sure about #2. I see no calls to it in the code.
(Post 5049824)
Originally Posted by razorlab
(Post 5050670)
#1 and #3 BDEL are exactly the same in stock roms however.
Mrfred, if #3 is used when the BLVS is exceeded couldn't this be used to reduce boost in taller gears if needed? Or what else happens when BLVS is exceeded?
It could be used that way. Crossing over the BLVS also affects the WGDC update interval. It could affect other things that I have not researched yet.
(Post 5053008)
Originally Posted by codgi
(Post 5054438)
How does it affect that interval? Increase/decrease or is that something else you have to poke at :)?
