-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Which ROMID's have ICS (https://www.evolutionm.net/forums/ecu-flash/313691-romids-have-ics.html)
tephra Dec 16, 2007 05:28 PM
Hey Guys,
Can ppl just post up whether they have intercooler spray button or not and their ROMID?
My next round of mods will probably utilise this button.
Cheers
D.
Jorge T Dec 16, 2007 07:06 PM
9417008 has ICS
jba3 Dec 16, 2007 08:01 PM
Originally Posted by Jorge T (Post 5062604)
9417008 has ICS
Yes, same ECU ID I have. At first I got it confused with ISC. :o
fixem2 Dec 16, 2007 11:48 PM
96940011 No ICS
C6C6CH3vo Dec 17, 2007 06:43 AM
Would this be something I can use? It can be hard to beat the patch that you wrote existing from last summer. You are a code Genius! Sorry, I had to say that, but you deserve the Nobel prize more than that lying fool Gore.
96420007
96420008
I think all USDM 03 and 04's have them right?
logic Dec 17, 2007 10:16 AM
Originally Posted by fixem2 (Post 5063305)
96940011 No ICS
I can confirm this: 96940011, no ICS, 2005 MR.
Oracle1 Dec 17, 2007 11:34 AM
UK one has. 88570008
evo828 Dec 17, 2007 03:32 PM
EDM Evo 8 - 96530006 has it.
mchuang Dec 17, 2007 04:53 PM
94170014
tephra Dec 17, 2007 04:56 PM
hrmm ok - I'm going to release V4 of my mods today sometime, however it will only be for ICS equipped evo's
jba3 Dec 17, 2007 05:43 PM
I believe this is correct. The 03/04 had the ICS and the 05+ did not, but they may have left it in the ECU so we should double-check.
codymac Dec 18, 2007 11:46 PM
2006 USDM IX MR - no spray button
88590014
tkklemann Dec 19, 2007 04:49 AM
96940011 No ICS
Correct. We do have all the maps in the ROM...
But, my question is, couldn't we still use this assuming that since we (the 05 0011 ROM guys) do not have the ICS, the pins might still be on the ECU, just unused? If the pins are there, but unused, we could simply wire in a switch for the map switching.
Possible?
logic Dec 19, 2007 08:34 AM
1 Attachment(s)
This is a good point that I should have mentioned when I originally posted; I'm pretty sure the code and tables for controlling the ICS are there, so assuming the necessary hardware is in place on the ECU itself, adding a switch to pins 91 and 44 ought to do the job, no?
ko_racer Dec 19, 2007 09:28 AM
UK Evo VIII FQ300 93660005 - Does have ICS
