Evoscan maptracer help, again
So I have tried to load the 8890015(?) and the evo9base xml maps then my .hex file and I am still getting evoscan.xml is denied code. Can anyone help me with the maptracer on evoscan v2
yeah tried using the evoscan .xml and my .hex map and still get the denied window
What exactly do you mean with a denied window. An error? You may need to modify your ecuflash xml.
It said the same thing. When I used the evoscan rom and my flashed .xml file. U talking about I should copy and paste the evoscan rom to the ecuflash then relfash my car with that?
The error window that comes up says: Access to the path 'C:\Program Files\evoscan\evoscan v2.0 Map Tracer Edition\Evoscan.xml' is denied
Are you trying to load the 8890015 xml? I loaded my modded xml out of EcuFlash and didn't have a problem.
Originally Posted by 7oey
(Post 5198949)
This is usually a permissions problem. Make sure that you have the rights to access this file. Is there any chance that another program is using that file and locking it? |
Not that I know of
Excel will lock it.
