LTFT mid Fuel trims don't change
No matter what I do my ltft mid won't budge when changing the scaling. I've changed them from 597 to 636
They will not change from being negative. They tend to hover in the -9 to -12. I think this is causing my crappy cold starts(lean) in open loop with negative trims. On the other hand I've got the ltf lo pretty close to 0 by adjusting latencies. At WOT AFRs are consistant from run to run- 83-85 IDCs at 11.3 -7200rpm mods are: Evo8-, modded airbox drop in filter, pte 680, cams, ported exmanifold, 9gt turbo and 3" TBE no boost leaks or exhaust leaks I have the cams set at +1i/-1e What else can I look for? |
| All times are GMT -7. The time now is 11:34 AM. |
