-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Can't flash my ECU... (https://www.evolutionm.net/forums/ecu-flash/339049-cant-flash-my-ecu.html)
bboypuertoroc Apr 14, 2008 12:27 PM
For some reason, I can't flash my ECU with my Tactrix cable anymore. I can log just fine, but I cant flash or pull a flash. I tried a friend's cable and it worked fine. Tried my cable on his car and could only log. Any way to fix it other than having to get a new one?
Mellon Racing Apr 14, 2008 12:31 PM
I've seen that quite a few times with other customers...seems some cables go bad. i would contact tactrix and see if they will exchange it for you.
bboypuertoroc Apr 14, 2008 12:33 PM
Thanks Chris.
BTW, we got at least five right now. I'll get in touch with Brad and let him know so we can start looking at some dates.
bvdawg13 Apr 14, 2008 12:33 PM
im having the same problem right now actually....starting to think its my cable
bvdawg13 Apr 14, 2008 12:37 PM
Would anyone happen to know what this means? I try to read my rom and it gives me this message:
[15:04:18.796] Using interface OpenPort 1.3 Mitsubishi TX14sjXh0d8ff6c900000000000000000000000000000000
[15:04:18.796] interface close
[15:04:18.812] unable to connect to vehicle interface.
[15:04:18.812] interface close
EvolNinja Apr 14, 2008 12:42 PM
Just got mine today. Waiting for hallman mbc, swoosh boost gauge and aem wb O2 before i'll start logging.{thumbup}
EvolNinja Apr 14, 2008 12:43 PM
i think it's the version you're using. I heard some version of the ECUFlash is corrupted.
bvdawg13 Apr 14, 2008 12:48 PM
ya ive just downloaded the most recent 1.34 and i have tried to uninstall/reinstall several times
newbieEVO8 Apr 14, 2008 01:44 PM
Originally Posted by bboypuertoroc (Post 5541294)
Thanks Chris.
Thats cool man.
You can hit me up on AIM if you want. (mellontuning)
fugiwara Apr 15, 2008 05:42 AM
it has nothing to do with the version, it's obvious, you use your friend's cable and you can flash/read, but your cable can't. so it's tactrix cable problem, if you own it for less than a yr, call them up! mine had the same problem and i call and got new one.
also, don't leave the cable plugged if not using it!
