Can't get Mitsulogger to work
So I downloaded the newest Mitsulogger, unzipped the file, and when I go to start it from the folder that is created, the little "dashboard" box pops up for a split second, then I get a Windows error message. Am I doing something wrong that I don't realize. I tried searching, and didn't find anyone else having similar problems. I'm a total noob to tuning, so be gentle lol
do you have .NET framework 2.0 or higher installed on your computer?
I do, but I'm going to do a re-install to see if that fixes anything
Nope, still not working. Might just go ahead and get EvoScan
Originally Posted by premo
(Post 5546074)
The only error messages you would typically get are either .NET framework, or a driver problem, and those are rare.
Are you attempting to run the application in windows Vista? If you are, make sure the application shortcut is set to run as administrator. Also, when you unzip the file, all of the files in there HAVE to be unzipped into the same directory. If you don't, it will generate an error. Thats all the common things I can think of. |
Oh, it will get an error if you run it from a network share... but that doesn't normally`apply to most users
| All times are GMT -7. The time now is 01:32 AM. |
