-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Reading CEL's with Tactrix (https://www.evolutionm.net/forums/ecu-flash/344957-reading-cels-tactrix.html)
Davo May 12, 2008 08:18 AM
Got the cable and cd from tunertools
can i read cel's with the datepro software given on the cd or do i need another program?
Thanks
TeStUdO May 12, 2008 08:20 AM
You can download ScanTech from Aktivematrix for free and be able to read and clear CEL's.
Davo May 12, 2008 09:06 AM
thank you
Chabada15 May 12, 2008 01:18 PM
evoscan does it too, works on my 05 VIII
diiirk@AwdMotorsports May 12, 2008 01:20 PM
i use scan tech. works great.
G20 May 12, 2008 02:03 PM
ScanTech works great. It's also show you the freezed frame when the code hapenned so you can use the info to analyze.
mountainturbo May 12, 2008 02:44 PM
I can't seem to get scantech to connect. Is there anyone using it successfully with Vista? Or is there another program I can try?
andrewzaragoza May 12, 2008 03:29 PM
it should work you should just make sure u select tactrix cable and the com port it is in. you can check the com port via the device manager from the control panel.
mountainturbo May 12, 2008 09:45 PM
Yah, I did that. When I try to connect, it initializes and everything, but cannot connect for some reason. I read in another thread that it might have to do with old drivers the program was written for that are not the same in Vista, so that's why I was wondering if anyone else had gotten it to work.
EvoDan2004 May 12, 2008 09:45 PM
i cant even get it to work. i dont know. i think im getting it from the right web sight. but after i download it and install it i goto open scantech and it says some weird code and that it might be missing files or some crap like that.
EvoDan2004 May 12, 2008 10:19 PM
here is what is going on. lol in picture no less.
i am downloading it from here.
http://i181.photobucket.com/albums/x.../untitled1.jpg
i then click the download tab you see and i am brought to a screen that tells me i have to except to download. which i do and then this window pops up. i tryed both ways to save or download and im brought to the same screen
http://i181.photobucket.com/albums/x.../untitled2.jpg
here is where im brought to this
http://i181.photobucket.com/albums/x.../untitled3.jpg
then i click the scantech and extract it to my c-programs file
in the mean time i have a scan tech folder that poped up on my desk top along with the winwar zip folder
now when i open the scan tech folder it opens winwar back up and then shows this inside
http://i181.photobucket.com/albums/x.../untitled4.jpg
now i have no clue what the hell to do from here. so i click where the blue line is. and i get this.
http://i181.photobucket.com/albums/x.../untitled5.jpg
now its not saved anywhere. i dont know if this is it or not or if it will work.
i have tryed to extract this to my program files as well and then thats where i get this
http://i181.photobucket.com/albums/x.../untitled6.jpg
and thats hwere im at now. i must be doing something wrong. but i have tried for hours and hours and i cant get the damn thing to work. lol HEEEEEEEEELP im a retard
EvoDan2004 May 12, 2008 10:24 PM
wow i am dumb as dirt.... i got it to work. i was clicking the wrong thing in winwar. hehe. oops.
hehe anyone want to help me set it up????
oldevodude May 12, 2008 10:49 PM
Wel lfirst of all you need to extract ALL the files from what you see in winrar.
Select them all and extract to a folder you create then run setup.exe to install the program. When running Vista it will say about ten files already exist and you must say overwrite. after you are done installing you need to reboot then try to detect com port. As mentioned earlier you can look in device manager under ports to see what port number your tactrix cable is. go to setup in Scantech and select the correct port.
Good Luck hope this helps
Davo May 13, 2008 05:33 AM
i had a tough time with it but eventually got it to work and work it did
i got the screen after doing the setup where it listed like 4 possible errors
what i did differently was after i made the setting changes and accepted the changes, instead of auto detecting, i choose the green tick, first icon on top and it did its thing perfectly
my niggling p0125 again
thanks guys and hope this helps some of u out there
Jspec EVO VIII May 13, 2008 08:55 AM
I have the scantech but for some reason it wasn't working for me. Gotta try it again sometime this week and see if works again.
