now simulating front O2 signal using WB signal
1 Attachment(s)
I finally finished up debugging and proof testing my front O2 sim + rear O2 sim patch this evening. Using just the WB analog out on my LC-1, I can now control the closed loop AFR and simulate the rear O2 sensor. :-) What I tested this evening was just a first draft. There are two limitations of this v1 patch:
1) The target closed loop AFR is hardcoded to 15.5:1 rather than being adjustable. 2) The afr "width" of the simulated NB signal is not adjustable. I didn't bother with these items in the first draft because I wanted to see the setup work before I spent any more time making the setpoint adjustable. Anyhow, I went out driving for about 1/2 hour, and it worked very well. My only concern is the possibility of stalling when pushing in the clutch when coming to a stop. It didn't happen during my test run, but the idle did get more dodgy than usual one or twice when coming to a stop. Some people have mentioned surging when using the LC-1 simulated NB output. I didn't notice anything like that. I plan to continue testing it for the next few days, and hopefully by next weekend, I'll be ready to post a patch for the 88590015 ROM. If there is widespread interest in the patch, I'll talk with tephra about whether he'd like to add it to his tephra ROM. Here is some data from one of my logs: https://www.evolutionm.net/forums/at...hmentid=122153 |
Freaking sweet! Let me know if you want help logging/testing, of course it'd need to be for 96530006..... :D
You da man mrfred, youdaman! Proof of concept works! Obviously it's setup to just use the hardcoded AFR during open loop, perhaps it could be disabled during low-load conditions (10?) to help avoid the stalling issue? |
Very cool stuff as always.
So you idle at 15.5 too? My cams would hate that. |
what would be cool is if you can make the fuel map an actual target AFR map, which the ECU then targets by using the wideband + changes...
that way we can run closed loop @ WOT for actual target AFR's. not that I would trust the LC1 (or any wideband) to stay configured/calibrated correctly... |
repost
Originally Posted by tephra
(Post 5908599)
I was having problems with my car running really rich a little while back and during all the things I tested I decided to try running the lc-1 as the front o2 to see if that fixed the problem. But it didnt.
After finding out my problem and got it fixed I kept the WB signal attached and the car runs great. I havent experienced any problems with it at all. I just crimped two male spades on the front o2 wire from the sensor and the yellow narrow band signal from the lc-1 and put a female spade on the ecu pin out. I dont have the pins so thats how I did it. Im going to buy some and re-do it though along with simulating the rear to something else also. I have an 03 with rom id 9417008. I have pretty much all supporting mods besides a built long block. |
Originally Posted by mrfred
(Post 5908304)
just like using zeitronix.
(Post 5908599)
(Post 5909048)
Cute idea. Can and will definitely do this. This will very nicely handle idle AFR needs. No way I would try or recommend running closed loop WOT though.
Now have a draft of v2. v2 uses the AFR in the AFR tables to set the closed loop AFR. I'm a little burned out for the evening, so I'll debug and test later this week.
awesome work as always mrfred. You never cease to amaze me!
SQ |
You guys rock so hard:headbang: :headbang: :headbang: :headbang:
Do want for 88590015 This might be dumb, but how much space does it take up and how much of a chance is there for this to be integrated for map switching to allow different lambdas on each map? That would make E85 life a bit better, no? I really need to fly around the world and buy you guys a :beer: one day. |
No need to fly around the world for mrfred, he's in the usa (not sure where?). Tephra on the other hand, he's down under :)
