-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   not sure whats going wrong....mitsulogger won't log correctly (https://www.evolutionm.net/forums/ecu-flash/368762-not-sure-whats-going-wrong-mitsulogger-wont-log-correctly.html)
evane Sep 11, 2008 05:25 AM
1 Attachment(s)
i have no idea why but my logs from mitsulogger are way out of wack! don't know whats going wrong here....its only 15 seconds of the log but there rest of it is just the same
ranz Sep 11, 2008 12:45 PM
have u tried reinstall mitsulogger!!
fryedchikin Sep 11, 2008 04:40 PM
Did you have "Demo Mode" selected ?
ranz Sep 12, 2008 03:23 PM
^ +1
MalibuJack Sep 12, 2008 07:57 PM
If for any reason the cable is not detected, demo mode is automatically selected to avoid getting errors.
Make sure the dropdown for the cable is showing your cable, if not, redetect it and make sure its selected, then uncheck the demo mode checkbox.
Demo mode is designed/intended to allow you to test calculations for requestID's as it will randomly run through numbers from 0-255 and generate weird data like you see.
