Tuned car and now it won't start.
Ok I put together a tune for my car and it won't start when I upload it to the ecu. When I upload the stock tune it works; I checked the immobilizer code and its the same. I can turn the ignition and you'll here it crank but it won't fire up it won't fire up.
Does anyone know what this could be? Thanks for all your advice. |
You "put together" a tune? Not sure what exactly that entails...logging I hope.
Why not just change the timing, fuel and boost in the stock map since it works and starts, then save it as "put-together-tune.hex" that way you can revert back to stock? |
That happened to me when i changed from the 0008 to the 0014. it ended up being the RPM setting in the Valet mode was too low. check some of those setting if you are using a mod with one.
are you flashing the same rom or a different one?
| All times are GMT -7. The time now is 03:43 PM. |
