Urgent: USDM EVO8 Doesn't Start anymore, help needed please
Hello guys,
yesterday I was tunning my friends EVO7 european spec using tactrix 1.3U cable and ECUflash 1.38, everything went well, after we were done, another friend asked to tune his USDM import EVO8, so I read the stock rom off his car, modified some fuel, timing, boost tables and then flashed back, everything was going as normal so far, till we tried to start the car and it didnt start, so I went into ECUEdit and tried to access logger and it said "ECU no response", I flashed back stock rom and still pbm was not solved, the stock ECU ID#MN132874 RomID # 94170014 so I said ok, I have an ECU that I bought off ebay, ECU # MN132874 and RomID: 94170008 so I swapped ECUs, and went into logger and the ebay ECU worked fine, tried to start car it did not start, I said ok since it has different Immo code, so I copied the immo code from stock ECU to ebay ECU and flashed. and the same problem happened, logger can't access ECU anymore, diagnostic tool cant find ECU, and car doesnt start. I can read rom and write rom, but nothing else does work? what should I do? Kind Regards Billy |
Try flashing the stock ROM you got at the start over the new ECU.
You are using ecuflash and evoscan yeah? whats ecuedit?? |
I tried flashing stock file over both ECUs and pbm was not solved, ECUedit is from Epifan, I tried reflashing with ecuflash and with ecuedit also with romraider and with the 1st 2 programs I succeeded in reflash but car doesn't start, with the last program it said "ECU definition not found" basically coz its a Sube based program.
do you think I should reflash the EVO7 rom everybody use when they buy an EVO8 ECU?? is my pbm an Immo blocked ECU? thank you |
Just use EcuFlash - not sure why your trying other ones.
What happens when you flash the ROM that you originally downloaded from the car? Did the car turn over? start then cut out? |
^^^^^^^^^^^^^{thumbup} ^^^^^^^^^^^^
Originally Posted by nabilsx
(Post 6187991)
thank you can you verify to us here that ecuflash is completing it's flash by posting the verbose info it gives/or double checking? also, what year is the evo8? good luck. |
I did use ECUflash, it didnt work (I mean car didnt start) thats why I used the others I wasnt sure pbm was ECUflash or something else.
No, the car doesnt start, I check every fuse and all are well, when I crank it, it just cranks doesnt start. and when I flashed stock file back or any file, it doesn't show any error messages, it shows that everything went as it should. thank you |
(Post 6188041)
well minutes before I flashed the EVO8 I have been tunning an EVO7 for 2hrs and had no pbms at all, anyway this is what I got when I flashed the stock rom back to ECU and asked to compare file with ECU
-- New session started at 10/2/2008 9:45:02 PM : Compare process with template Evo 7,8 16-bit -- [0.000] loading kernel from file C:\Program Files\ecuEdit\kernels\m7052_v103.bin [0.015] 3588 byte kernel read [0.016] 262144 byte image read [0.063] found OpenPort 1.3U cable [8.562] sending init sequence 1 (0001) [1.063] read 0x05 response [0.015] sending init sequence 2 [0.047] read 0x1B response [0.016] sending init sequence 3 [0.484] writing kernel area addr: FFFF8800 len: 0E04 [1.906] kernel get version [0.047] kernel version is : OpenECU Mitsubishi SH7052 Kernel V1.03 [0.016] reading kernel comm buffer size [0.047] comm buffer size set to 512 [0.015] reading kernel flash buffer size [0.032] flash buffer size set to 4096 [0.312] comparing ECU flash memory pages to image file [0.047] page 0 from 000000 to 000FFF crc32 E42003A6 file_crc32 E42003A6 :: YES [0.062] page 1 from 001000 to 001FFF crc32 B7E7F5C3 file_crc32 B7E7F5C3 :: YES [0.063] page 2 from 002000 to 002FFF crc32 9EBEFC12 file_crc32 9EBEFC12 :: YES [0.062] page 3 from 003000 to 003FFF crc32 7A4B5594 file_crc32 7A4B5594 :: YES [0.063] page 4 from 004000 to 004FFF crc32 37A6E576 file_crc32 37A6E576 :: YES [0.062] page 5 from 005000 to 005FFF crc32 77EF67BE file_crc32 77EF67BE :: YES [0.063] page 6 from 006000 to 006FFF crc32 B9D2C2FB file_crc32 B9D2C2FB :: YES [0.047] page 7 from 007000 to 007FFF crc32 2A8CF5E9 file_crc32 2A8CF5E9 :: YES [0.156] page 8 from 008000 to 00FFFF crc32 8B6B957F file_crc32 8B6B957F :: YES [0.297] page 9 from 010000 to 01FFFF crc32 4BCDC4EA file_crc32 4BCDC4EA :: YES [0.281] page 10 from 020000 to 02FFFF crc32 3EB5B1CF file_crc32 3EB5B1CF :: YES [0.297] page 11 from 030000 to 03FFFF crc32 AB9A8EC1 file_crc32 AB9A8EC1 :: YES [0.016] readed image is identical with ECU [0.078] The operation completed successfully Basically all what I did was tunned the fuel and ignition tables and flashed back, then with the Ebay ECU I only changed Immo code and flashed back, but in both cases car doesnt work now :-( Thank you |
(Post 6188056)
mmm - very strange
perhaps your "stock" image got corrupted. |
by disable Immo bits you mean to set it to FFFF? I doubt ecuedit is the pbm, since you can check the stock rom I attached using ECUflash and everything seems pretty normal.
no - its one of the 0xFAA bits... can't remember which one!
ok I will search for this 0xFAA bit, thank you, so you think I should try one of those EVO7 roms?
thank you |
(Post 6188107)
thank you EDIT: i couldn't remeber either! i had periphery excel sheets open and then forgot which is bit 0 and which is 15. then i got my calculator out and punched in 56d2-->bin and matched all the 1's and 0's and concluded its bit 3. so... if you do the 1.35 and above ecuflash periphery xml mod, set FAA bit 3 (remember 3 is the fourth number lol) to '0' if you do just the FAA hex input xml mod, enter in '56D2' |
| All times are GMT -7. The time now is 06:14 PM. |
