MDP questions? ?
Can the MDP sensor be used to monitor vacuum conditions?
I ask this because I cannot get a vacuum reading. Boost (MDP) in EvoScan reads in the 50s at idle which I know is incorrect because of the vacuum condition at idle. I assume most of you will tell me to get the JDM MAP sensor and be done with it. |
Originally Posted by Appauldd
(Post 6595236)
I ask this because I cannot get a vacuum reading. Boost (MDP) in EvoScan reads in the 50s at idle which I know is incorrect because of the vacuum condition at idle. I assume most of you will tell me to get the JDM MAP sensor and be done with it. would be great is there was a two way pressure sensor heh.... correct me if i'm wrong please. EDIT: please do tell me there is vacume resolution on the JDM 3bar and i'm wrong. if so, i'm buying one right now. |
^MAP sensors measure absolute pressure. From -14.7 and up. Meaning vacuum is seen as pressure by them. So yes there is vacuum resolution, if that's what you're asking about JDM MAP...
OP, stock MDP is a 1 bar, meaning it should show vacuum values.. Maybe Evoscan calculation/address is wrong? |
Originally Posted by mplspilot
(Post 6596152)
OP, stock MDP is a 1 bar, meaning it should show vacuum values.. Maybe Evoscan calculation/address is wrong? what should the EvoScan calc be??? |
(Post 6596152)
OP, stock MDP is a 1 bar, meaning it should show vacuum values.. Maybe Evoscan calculation/address is wrong? to OP, i get your same issue when logging the MAP with evoscan--i gave up a while ago lol. i'll check this out in detail again tonight. thanks |
atmo isn't 0v on the MAP sensor, its like 1.6v.
so anything under 1.6v is considered vacuum. I dont know what formula to convert -psi into hg/mm (orwhatever vacuum is measured in) |
Originally Posted by tephra
(Post 6596755)
so anything under 1.6v is considered vacuum. I dont know what formula to convert -psi into hg/mm (orwhatever vacuum is measured in) i have the crappy usdm MAP. it's a hair under 4v or so it says lol. i tried manipulting the cal tables a while ago to the usdm linear curve, but i still couldn't get proper vacume tunability [with bez's code]. i'll try again as maybe i gave up too quick lol. |
(Post 6596755)
My question still remains......what should the proper calculation be set as in EvoScan for reading the MDP???
depends on the MDP. what one is it?
(Post 6597986)
Stock The reason for my request is because I am working on the MAP to MAF patch. I have my car running pretty well but I cannot get accurate with VE if I don't have accurate vacuum. |
what the 1bar version?
(Post 6598022)
I am also running the 94170015 with your 5.10 mods. You really are the man!{thumbup} |
hrmm not sure what the scaling for the 1bar map sensor is. actually isn't it in evoscan already?
Thats the problem. I cannot get a vacuum reading. The Boost(MDP) setting in EvoScan never goes negative. At idle it hovers in the 30s.
