88590015 - MUT 8A = 0-100% Throttle position
I guess BEZ has made mistake on this one.
For those who can read math Throttle Position = 100/222(MUT_8A - 33) {%} OBDII PID11 is calculated in below code sequence, for those who can read code. 88590015: Code:
ROM:0003AA8A mov.l @(h'24C,pc), r4 ; [0003ACD8] = MUT_8A |
MUT_8A is load_error in Evoscan 2.5, what does it have to do with throttle position? Have i missed something?
EvoScan uses what BEZ_BASHNI has deciphered, I think he made a mistake on this one.
I see the other calculation, but i don't understand what is has to do with throttle position.
Throttle position is MUT_1F and not MUT_8A What is MUT_8A by the way? |
Speaking of 88590015, when you look at FFFF6ACC occurences, you will find that it is TPS with the offset.
MUT_17 is TPS ADC Voltage reading 0-5V MUT_1F is ECU Load |
Acamus, do you know if anyone has found the MUT table equivalent for OBD outputs? I mean, when you connect a normal OBD2 scan tool to the car and view live data, it does not seem to use the MUT table. Changing the MUT table doesn't seem to effect these OBD outputs.
The reason for asking is that almost every OBD type device I have seen will always show TPS as absolute and not as a calibrated form for the evos. If MUT 8A is TPS scaled, then maybe there is a way to change the OBD output to show the calibrated TPS. |
No, there is no "OBD Table" complement/equivalent, it is implemented like
Code:
switch(obd_mode) Code:
ROM:0003AA8A mov.l @(h'24C,pc), r4 ; [0003ACD8] = MUT_17 |
Originally Posted by acamus
(Post 6632417)
I think that is the same on 99860002,read my old post
https://www.evolutionm.net/forums/ec...ml#post6437353 |
Yes it is true, for any ROM, I forgot to mention, I am just picking the "well known ROM" that anybody can search the code sequence, I am glad that you already posted the picture. I was about to create one.
Have you discovered what is the true MUT for Load error?
It is very annoying tune boost on evo VII (99860002 and 9055001 also) without the load error log :crap: For EVO IX (8884001x) instead MUT 8A works well. EDIT : In the MUT table,for 9986002 and 9055001 in MUT 8A i have 8803 and in MUT 8B 8BE3. For 8884001x MUT 8A = 6ECF and MUT 8B = 6EC5 Could this be the problem? |
Originally Posted by eTiLiKo
(Post 6779925)
It is very annoying tune boost on evo VII (99860002 and 9055001 also) without the load error log :crap: For EVO IX (8884001x) instead MUT 8A works well. EDIT : In the MUT table,for 9986002 and 9055001 in MUT 8A i have 8803 and in MUT 8B 8BE3. For 8884001x MUT 8A = 6ECF and MUT 8B = 6EC5 Could this be the problem? differences in hex addresses of variables are expectant as the ROM size differs and code differs for different markets/engine setup. |
