-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   accurate 90550001 xml's (https://www.evolutionm.net/forums/ecu-flash/407550-accurate-90550001-xmls.html)
japanevo Mar 18, 2009 11:32 AM
just looking for some accurate 90550001 rom xml's. after i upgraded to ecuflash 1.41 half of my definitions disappeared. so i went back through and set everything back up but now some of the maps and such look a bit off.
cossie1 Mar 18, 2009 06:34 PM
1 Attachment(s)
Here you go.
Use 1 or the other, don't put both in the ecuflash directory together.
japanevo Mar 20, 2009 05:32 AM
sweet, thanks. you rock.....
cossie1 Mar 20, 2009 06:04 AM
no probs
japanevo Mar 23, 2009 08:11 AM
1 Attachment(s)
well it still didn't work for me but i found out why. somewhere along the line i had switched over to 96530006 and in the process i ended up with a newer version of the evo7base xml. a lot of the tables that were in the new xml had changed, mostly just names. so after adding the tables that i was looking for and fixing a few other little things i have managed to put together a pretty complete evo7base xml. i tried to keep all the correct addresses from the 9055 xml cossie sent me. also, i have included my 7base in the zip file as well as a txt with a couple of tables that are giving me some trouble. some of them aren't that important, to me at least, but they were originally there so i am sure someone has use for them. i did try opening a couple of other roms with my new 7base and they looked like they were fine but i wasn't totally sure if they were complete. if someone wants to take a look and tell me what they think. once it is squared away i am going to submit it to jcbanks for the ecuflash update.
thanks
mike
krazykorean84 Sep 23, 2011 08:01 PM
I hate to bring this thread back from the dead but I'm trying to find a good xml for 90550001. Every thread I come across has broken links or unusable downloads. Just need a good 90550001xml so I can view a buddy's rom. Can anyone help?
krazykorean84 Sep 24, 2011 10:06 AM
Bump.
todd6027 Sep 24, 2011 02:25 PM
1 Attachment(s)
try this
krazykorean84 Sep 24, 2011 06:58 PM
Originally Posted by todd6027 (Post 9626689)
try this
Doesn't work. Says file is corrupted or invalid. Does anyone have a good XML for 90550001?
dparrish Sep 24, 2011 09:48 PM
There is one at http://ecurom.googlecode.com/svn/tru...o/90550001.xml
You also need evo7base.xml which is at http://ecurom.googlecode.com/svn/tru...o/evo7base.xml
krazykorean84 Sep 25, 2011 04:48 AM
Originally Posted by dparrish (Post 9627263)
Awesome! Thank you very much. {thumbup}:beer::mitsu:
