-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   AFR's with CAT (https://www.evolutionm.net/forums/ecu-flash/417030-afrs-cat.html)
sponners Apr 27, 2009 01:27 PM
AFR's with CAT
Hi all, a friend of mine wants me to check the fueling on his subaru, the car is stock but has just been rebuilt.
my wideband is used with a tailpipe sniffer, so am wondering how the stock catalytic convertor affect afr readings?
{thumbup}
RoadSpike Apr 27, 2009 01:31 PM
{thumbup}
Come on man you know its going to look crazy lean out the tail pipe with a cat on it.. Slap a test pipe on it or your not going to get the correct readings.
sponners Apr 27, 2009 01:44 PM
I dont know what the readings are going to be like.....hence the question.
have heard a tuner here in the uk say it was about 0.6 (afr) different.........don't know if that was a constant though through the rev range.
.....pain in the arris to put a decat (test pipe) on the scooby downpipe....specially with rusted turbo bolts.
(but surely this also wouldn't give a correct reading as it is being run with the restrictive cat)
RoadSpike Apr 27, 2009 01:50 PM
Its going to be consistently high if the cat is functioning.
If its a major problem maybe goto an exhaust shop and have them weld in a bung?
Sorry to hear its a scooby i know those exhausts can be a bugger! What kind of scooby is it?
sponners Apr 27, 2009 01:59 PM
the scoob is a stock '98 uk wagon (bar a fuel reg), car is running fine at the moment after the rebuild but was wondering if I could check the fuelling at the tailpipe without too many issues.
I was wondering if anyone has done any logs with a wideband pre and post cat, is there a constant calculation I could use to get a semi-accurate reading.
don't really know how a cat works, will readings vary from one cat to another?
{thumbup}
sponners Apr 27, 2009 02:01 PM
just found this on google
http://www.innovatemotorsports.com/f...ad.php?p=12691
Dennis F Apr 27, 2009 02:02 PM
{thumbup}
I think you would have to many variables to use a constant.
A cats efficiency can change over time and I believe that would mess up your readings as well.
Have a bung welded in pre cat, take it to the dyno and when done, use a bolt to block it up.
sponners Apr 27, 2009 02:08 PM
precat would be right next to the turbo, isn't too much heat bad for the o2 sensor.
....will be checking car on the road (not a fan of rolling roads/dynos)
THUB Apr 27, 2009 02:26 PM
You'll need to use a heatsink. Innovate includes super simple instructions in their manual which you can get online.
