-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Too rich AFR's causes knock? (https://www.evolutionm.net/forums/ecu-flash/420654-too-rich-afrs-causes-knock.html)
daymean May 13, 2009 10:14 AM
Hi guys,
Been on the forum for some time, browsing and reading alot...wanna gather as much info as possible before i start modifying my car (E8 MR JDM).
I know that too lean AFR's can lead to knock, but can too rich AFR's also lead to knock?
clockworktoy May 13, 2009 11:05 AM
Yes overly rich afr's can also cause knock.
MR Turco May 13, 2009 11:46 AM
it can cause knock. It can also saturate the cylinder walls with gas and prevent proper oiling as well as fuel mixing with the oil.
daymean May 13, 2009 12:14 PM
hmm....what sort of AFR's would tend to cause this high AFR knock? values less than 10.5 maybe?
SLO-EVO May 13, 2009 12:35 PM
10.5 AFR is very rich..
rolly1818 May 13, 2009 12:45 PM
i have had my AFRs @ 10.5 and have seen no knock.
maybe richer.
daymean May 13, 2009 01:03 PM
rolly1818, when ur car was stock what afr's did u see?
kanyonkid May 13, 2009 01:15 PM
stock evos run richer than 10.0 during wot... thats as low as my gauge reads
rolly1818 May 13, 2009 01:23 PM
i saw 9.8 after an exhaust install.
iTune May 13, 2009 08:45 PM
Yes, excessively rich AFR's can and will cause knock. But we're talking AFR's well below 10.0:1 in most cases. Not to mention "Bore Wash".
clockworktoy May 14, 2009 12:12 AM
I was running 10:1 afr's and it was causing knock in the higher rpm range even after retarding a good amount of timing. Now with closer to 11.3:1 no more knock.
mrfred May 14, 2009 11:14 AM
One thing that wasn't mentioned is that rich knock looks different than lean knock. Lean knock tends to result in strong knock spikes where as rich knock tends to come on slowly over several hunderd RPM and stay at fairly low levels, usually a knock sum of 5 or less in my experience.
