HELP:Can't view all my parameters for my rom (newbie).
Well I went to get my car tuned this past Friday. Saturday I tried to view my rom at the track so I could make adjustments to my rev limits but my tactrix cable wouldn't let me into the ecu to view it. I got in touch with my tuner and he said it was because I had to switch my roms to allow map switching (he said I needed 96530706). He sent me the xml for it, but after adding it in my xml file, I could only partially view my rom. I still could not view the any of the Misc. section (stationary rev limit, rev limit, etc.). I checked my rom info and it said that I have 96530202. My rom also has tephramod-v7t6. If anyone can help me I will send them the xml to view it. Any help is truly appreciated. Thanks in advance.
William |
1 Attachment(s)
What is your User Level? If your tuner gave you an xml file, you need to put it in Program Files -> Open ECU -> Ecuflash -> rommedata -> Mitsubishi -> Evo.
Originally Posted by dolphin888
(Post 7392720)
EDIT: Nevermind. I see the pic you posted. Let me try this out and I'll let you know if that helps any |
Originally Posted by lillev23
(Post 7392743)
I followed that exact same order. Where would I check my user level at?
EDIT: Nevermind. I see the pic you posted. Let me try this out and I'll let you know if that helps any Set it to "Developer" level. |
I was already set at the developer level.
Then it can be something wrong with your xml file, I would try a "clean", untouched xml file...
(Post 7392843)
(Post 7392925)
. Also, would this change anything in my tune?
Maybe someone will share xml file you need, because I don't have it:) |
Is there something in the xml that I already have that I could change to be able to view my the rest of my rom?
| All times are GMT -7. The time now is 06:41 AM. |
