Using lean spool tables to match AFR's
Hi Guys, been thinking and wanted so input from the more experienced guys.
As you know with scaling the injectors your fuel map AFr's more often dont match your Actual AFR's SO Now can we not use the "lean spool AFR mapping" table to compensate the difference at various AFR's so that the numbers in the fuel table actually match the real afr's and the ecu then does the calc via lean spool to get the number its after. or will this not work? Mike |
Originally Posted by Boosted GP
(Post 7525046)
Just scale your injectors correctly and your airflow sensor as well. Lean spool was designed to screw your AFRs up, not fix em.
Originally Posted by jrohner
(Post 7526552)
You don't want your ECU doing this, those AFR numbers are only a reference. |
Disable lean spool through the periphery bits. Your actual AFRs should be damn close to the table values at that point. The values are right in the table.
The "lean spool AFR Map" table is what's causing the AFRs to not match the main fuel table under short burst of acceleration. Do some reading on the "lean spool" system. Pay attention to more recent threads as the overall understanding of the system has improved dramatically in the last year or so. |
Originally Posted by 03whitegsr
(Post 7528416)
The biggest change I found that works is rescaling the MAF, for me that got it very close.
My point is that if lean spool is disabled and the car is ran in open loop, it's very likely the MAP AFR values are very close to actual AFRs.
Trying to tune the lean spool AFR map to match the actual main fuel map is completely counter productive as that map is specifically meant to make the actual AFR NOT match the main map. |
Originally Posted by davidbuschur
(Post 7528697)
Originally Posted by C130flyer
(Post 7529561)
At what point is rescaling the MAF necessary?? Bigger turbo cams head stroker???
I dont understand why people want to make it so the AFR in the fuel table are the same AFRs logged.
If you spent all the time to make the AFRs match, when you changed mods, you'll have to re-do it all anyways. |
Hi,
thanks for all the replies, My AFR's are very close (0.1) and it was more by luck on the injector scaling and latency than by trying to get it there Was just a thought for those with ay off numbers to help bring it a bit more to reality. Mike |
Originally Posted by Evo_Kid
(Post 7530048)
| All times are GMT -7. The time now is 09:37 AM. |
