-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Can't find solution - Ecuflash doesn't react for xml changes (https://www.evolutionm.net/forums/ecu-flash/470971-cant-find-solution-ecuflash-doesnt-react-xml-changes.html)
TJung Jan 27, 2010 11:47 PM
Hey. My problem is that my Ecuflash doesn't reacting for .xml files changing. All the time I have the same tables, even when I copy modified xml's (for example tephra v5.1).
I've even tried to reinstall Ecuflash and still nothing :/
This is happening only on my new laptop with Vista Home Basic. On old laptop with Win XP everything is ok. Ecuflash 1.42.2595
Any ideas ?
PS. and one more: I am autodidact, so please forgive me guys, my english ;) I hope everything is understa[ble]
TouringBubble Jan 28, 2010 07:10 AM
Do you have multiple versions installed? Maybe modifying XML on the wrong directory?
TJung Jan 28, 2010 08:01 AM
No, only one. I'm not sure - maybe Vista holds deleted xml's somewhere ?
codgi Jan 28, 2010 10:32 PM
I'd go with a no :). So after you change the xml, have you ensured that the xml actually saved the changes? I know this sounds odd but that would be one thing to check.
Also are you changing the actual rom id.xml or the evobase<x> xmls?
TJung Jan 28, 2010 11:45 PM
I am not modyfing base xml's. I've exchanged them as You said: rom id.xml and the evobase<x>xml for v5.10 xml's.
Which inherits should using 88590015 with v5.10 ?
TJung Jan 29, 2010 10:22 AM
noone ? :(
TJung Feb 4, 2010 07:47 AM
Update. It's weird because with upgrading to V7, my Ecuflash is beehaving normal. All works, and it's reacting od .xml changing. Only with V5.10 is going bad
03lances Feb 9, 2010 10:03 AM
Maybe your user level was still set to beginner?
TJung Feb 9, 2010 10:51 AM
Nope ;) I've tried everything. Weeeird
