omni 3 bar settings...i've searched
to anyone who can help:
I see settings for JDM/EVO X MAP sensors and also for Omni 4 bar. Which of these am I SUPPOSED to use for the Omni 3 bar? I'm currently using the Omni 4 bar settings with the Omni 3 bar evoscan formula which as of now is giving me pretty good results. Just double checking and making sure I am using the correct settings. I saw someone asked this same question in the JDM MAP thread but no one replied. |
Are you just logging boost or trying to run ECU Direct boost control or maybe SD?
ecu direct boost with grimmspeed 3 port
On the scaling you need to make a graph comparing voltage values from the 4 bar, 3 bar, and JDM 3 bar and see where they all overlay.
I will be doing a right up on the proper voltage scaling for most of the sensors (other than the JDM 3 bar and Omni4) here shortly. In the meantime you should be able to use the JDM 3 bar voltage scaling and be pretty close. |
The Omni 3BAR matches the GM 3BAR with in 1-2%.
GM 3BAR: EvoScan: PSIG -> (x*0.17886) + 0.161 - 14.5 kPa -> ((5.0*x/255) + 0.01765)/0.01591 EcuFlash: To Display -> x*0.31 To ROM -> x/0.31 (Not sure if Direct Boost uses 10-bit ADC scaling like SD or not) |
thank you JB and Ceddy
| All times are GMT -7. The time now is 01:20 PM. |
