Denso 3 bar map sensor scaling help
Hi guys I have a Denso 3 bar map sensor installed and logging through ecu
Can some one give me the equation I need for evo scan for PSI I Have the following data I have just taken, my atmospheric pressure is 1032 hpa or 14.96 psi PSIg Volts Raw ADC 0 2.1 106 2 2.3 116 4 2.5 126 6 2.7 136 8 2.9 146 10 3.1 156 12 3.3 166 14 3.5 176 16 3.7 186 18 3.9 196 20 4.1 206 22 4.3 216 24 4.5 226 26 4.7 236 28 4.9 246 Also scaling and xml def for SD as I am going to convert to SD 96260009 as i can only find the GM,Omni extra |
