-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Need help. Just tuned, map sucked, tried a different map....car wouldn't start. (https://www.evolutionm.net/forums/ecu-flash/521231-need-help-just-tuned-map-sucked-tried-different-map-car-wouldnt-start.html)
SmurfZilla Oct 23, 2010 06:26 PM
I tried flashing back to to the original map.....it flashes fine but same thing.....car won't start. WTF.
I have a blaqops dbl pumper if it matters. I literally did nothing else but switch maps and I got nada. I dont think my fuel pumps are priming. I don't think I hear them (Damn defi warning buzz is too friggen loud when the car is on.
drifterific Oct 23, 2010 07:00 PM
Have you double checked your immobilizer code?
SmurfZilla Oct 24, 2010 05:31 AM
disabled
R/TErnie Oct 24, 2010 01:13 PM
unplug your gauge. You won't hear the pumps prime upon turning the key to on, but you'll hear them run after you stop cranking. pull out the rear seat lower cushion and the cover to hear it better :)
F0RSAKEN Oct 24, 2010 04:47 PM
What size fuel injectors, and are they scaled correctly?
mrfred Oct 24, 2010 08:20 PM
Try flashing the original map again.
05blue8 Oct 24, 2010 08:27 PM
It takes all of 10 seconds to pull the rear seats and unscrew the black panel covering the fuel pumps, or 20 seconds to unbolt the fuel feed line and direct it into a container. One crank either way and you'll know :)
