-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   can't connect to anything (https://www.evolutionm.net/forums/ecu-flash/529052-cant-connect-anything.html)
s.lamoureux Dec 10, 2010 09:57 AM
I've sent two support tickets to evoscan and they haven't replied back to me...
The first time I used evoscan I was able to connect to my car fine, but EcuFlash wouldn't work. Now, neither one will connect to my car. This is what i'm getting from EcuFlash:
[13:58:39.420] sending init sequence 1 (0001)
[13:58:42.680] sending init sequence 1 (0003)
[13:58:45.940] sending init sequence 1 (FFFF)
[13:58:49.201] sending init sequence 1 (F0F0)
[13:58:51.946] no response to any known code
[13:58:51.946] interface close
I have tried driving my car around to charge the battery, and running jumper cables while trying to connect so its not a voltage problem. I tried using an older version of ecuflash (1.29a) and uninstalling/reinstalling the drivers. I also used ECU Unlocker with EcuFlash to no avail. When I plugged the cable into my laptop the window popped up saying it was installing the new drivers so i'm pretty sure the cable is fine...i'm all out of ideas.
mirkoelek Dec 11, 2010 02:07 PM
I got the same issue... Did you come up with anything yet?
Carloverx Dec 11, 2010 02:56 PM
https://www.evolutionm.net/forums/ec...esnt-work.html
s.lamoureux Dec 12, 2010 04:11 PM
I have the 1.3U cable though so i don't know how i'd fix it, doesn't come in parts like 2.0 does
