-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   "Cranking Primer Initial Pulse", and RC 1000's on pump gas? (https://www.evolutionm.net/forums/ecu-flash/530270-cranking-primer-initial-pulse-rc-1000s-pump-gas.html)
nonschlont Dec 18, 2010 04:44 PM
Just curious, if you guys are adjusting this map w/ RC 1000's, for pump gas, or leaving it stock?
(0715 rom, most likely has a different name in other roms)
I know if I was running E-85, Id need to give it a bunch in the lower coolant temp region, to help w/ cold starts, but like I said, curious to see if u guys are adjusting it while on pump gas...
Reason Im asking, is I have -1 ms all the way down, but the lasty cell is -2ms lower than stock. =1ms @ 82*
TIA
