-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Car won't spark, Mitsulogger log attached (after I re-did wiring) (https://www.evolutionm.net/forums/ecu-flash/533276-car-wont-spark-mitsulogger-log-attached-after-i-re-did-wiring.html)
neonglh Jan 8, 2011 10:48 AM
1 Attachment(s)
So, if you haven't followed my wire tuck thread, I have moved my entire fuse block and battery into the interior, under the dash, as well as removed TONS of wiring. Doing so, I introduced a bunch of places for error. I tried to start the car the other night, and it cranks over, fuel squirts, but no spark. I am attaching a log I scanned with Mitsulogger, that shows some odd behaviors. Let me know what you think could be the cause. My grounds look good, as far as I know.
As you can see, the coolant temp is in the -370 range, and my air temp is in the -80 degree range. Obviously something is up.
125 rpm is cranking, 0 is not cranking. I tested my TPS, and that signal seems to work fine, from 10% up to 94%.
--mark
neonglh Jan 8, 2011 01:01 PM
Update:
I hooked the AEM up, and did some logging, and my coolant and intake temps are now working properly. I tested other things like battery voltage, tps, and everything looks good. I will hopefully get this all figured out!
--mark
